blacey
Sep 29, 2012Aspirant
3 drive failures w/in 10 days of 4.2.22 upgrade? #19570015
Within two days of upgrading my Ultra 6 with 6 2 TB drives in it to 4.2.22, it marked a drive dead. I always keep a spare so I swapped the drive out and completed a cross-ship RMA with Seagate. Befo...
blacey
System log for 9/28 Bootup and resync (i.e. I did not replace the second dead drive)
Sep 28 18:50:58 nas syslogd 1.4.1#18: restart.
Sep 28 18:50:58 nas kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Sep 28 18:50:58 nas kernel: Initializing cgroup subsys cpu
Sep 28 18:50:58 nas kernel: Linux version 2.6.37.6.RNx86_64.2.4 (jmaggard@calzone) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Thu Jul 26 05:00:36 PDT 2012
Sep 28 18:50:58 nas kernel: Command line: initrd=initrd.gz reason=normal BOOT_IMAGE=kernel
Sep 28 18:50:58 nas kernel: BIOS-provided physical RAM map:
Sep 28 18:50:58 nas kernel: BIOS-e820: 0000000000000000 - 000000000009c800 (usable)
Sep 28 18:50:58 nas kernel: BIOS-e820: 000000000009c800 - 00000000000a0000 (reserved)
Sep 28 18:50:58 nas kernel: BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
Sep 28 18:50:58 nas kernel: BIOS-e820: 0000000000100000 - 000000003f690000 (usable)
Sep 28 18:50:58 nas kernel: BIOS-e820: 000000003f690000 - 000000003f69e000 (ACPI data)
Sep 28 18:50:58 nas kernel: BIOS-e820: 000000003f69e000 - 000000003f6e0000 (ACPI NVS)
Sep 28 18:50:58 nas kernel: BIOS-e820: 000000003f6e0000 - 0000000040000000 (reserved)
Sep 28 18:50:58 nas kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Sep 28 18:50:58 nas kernel: BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
Sep 28 18:50:58 nas kernel: NX (Execute Disable) protection: active
Sep 28 18:50:58 nas kernel: DMI present.
Sep 28 18:50:58 nas kernel: DMI: / , BIOS 080016 06/10/2010
Sep 28 18:50:58 nas kernel: e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
Sep 28 18:50:58 nas kernel: e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
Sep 28 18:50:58 nas kernel: last_pfn = 0x3f690 max_arch_pfn = 0x400000000
Sep 28 18:50:58 nas kernel: initial memory mapped : 0 - 20000000
Sep 28 18:50:58 nas kernel: init_memory_mapping: 0000000000000000-000000003f690000
Sep 28 18:50:58 nas kernel: 0000000000 - 003f600000 page 2M
Sep 28 18:50:58 nas kernel: 003f600000 - 003f690000 page 4k
Sep 28 18:50:58 nas kernel: kernel direct mapping tables up to 3f690000 @ 1fffd000-20000000
Sep 28 18:50:58 nas kernel: RAMDISK: 3f50c000 - 3f690000
Sep 28 18:50:58 nas kernel: ACPI: RSDP 00000000000f9bb0 00014 (v00 ACPIAM)
Sep 28 18:50:58 nas kernel: ACPI: RSDT 000000003f690000 0003C (v01 061010 RSDT1112 20100610 MSFT 00000097)
Sep 28 18:50:58 nas kernel: ACPI: FACP 000000003f690200 00084 (v01 061010 FACP1112 20100610 MSFT 00000097)
Sep 28 18:50:58 nas kernel: ACPI: DSDT 000000003f690440 05B7D (v01 1AEOS 1AEOS005 00000005 INTL 20051117)
Sep 28 18:50:58 nas kernel: ACPI: FACS 000000003f69e000 00040
Sep 28 18:50:58 nas kernel: ACPI: APIC 000000003f690390 0006C (v01 061010 APIC1112 20100610 MSFT 00000097)
Sep 28 18:50:58 nas kernel: ACPI: MCFG 000000003f690400 0003C (v01 061010 OEMMCFG 20100610 MSFT 00000097)
Sep 28 18:50:58 nas kernel: ACPI: OEMB 000000003f69e040 00072 (v01 061010 OEMB1112 20100610 MSFT 00000097)
Sep 28 18:50:58 nas kernel: ACPI: HPET 000000003f69a440 00038 (v01 061010 OEMHPET 20100610 MSFT 00000097)
Sep 28 18:50:58 nas kernel: ACPI: GSCI 000000003f69e0c0 02024 (v01 061010 GMCHSCI 20100610 MSFT 00000097)
Sep 28 18:50:58 nas kernel: ACPI: Local APIC address 0xfee00000
Sep 28 18:50:58 nas kernel: [ffffea0000000000-ffffea0000dfffff] PMD -> [ffff88003dc00000-ffff88003e9fffff] on node 0
Sep 28 18:50:58 nas kernel: Zone PFN ranges:
Sep 28 18:50:58 nas kernel: DMA 0x00000010 -> 0x00001000
Sep 28 18:50:58 nas kernel: DMA32 0x00001000 -> 0x00100000
Sep 28 18:50:58 nas kernel: Normal empty
Sep 28 18:50:58 nas kernel: Movable zone start PFN for each node
Sep 28 18:50:58 nas kernel: early_node_map[2] active PFN ranges
Sep 28 18:50:58 nas kernel: 0: 0x00000010 -> 0x0000009c
Sep 28 18:50:58 nas kernel: 0: 0x00000100 -> 0x0003f690
Sep 28 18:50:58 nas kernel: On node 0 totalpages: 259612
Sep 28 18:50:58 nas kernel: DMA zone: 56 pages used for memmap
Sep 28 18:50:58 nas kernel: DMA zone: 2 pages reserved
Sep 28 18:50:58 nas kernel: DMA zone: 3922 pages, LIFO batch:0
Sep 28 18:50:58 nas kernel: DMA32 zone: 3495 pages used for memmap
Sep 28 18:50:58 nas kernel: DMA32 zone: 252137 pages, LIFO batch:31
Sep 28 18:50:58 nas kernel: ACPI: PM-Timer IO Port: 0x808
Sep 28 18:50:58 nas kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Sep 28 18:50:58 nas kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
Sep 28 18:50:58 nas kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
Sep 28 18:50:58 nas kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
Sep 28 18:50:58 nas kernel: ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
Sep 28 18:50:58 nas kernel: IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
Sep 28 18:50:58 nas kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Sep 28 18:50:58 nas kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Sep 28 18:50:58 nas kernel: ACPI: IRQ0 used by override.
Sep 28 18:50:58 nas kernel: ACPI: IRQ2 used by override.
Sep 28 18:50:58 nas kernel: ACPI: IRQ9 used by override.
Sep 28 18:50:58 nas kernel: Using ACPI (MADT) for SMP configuration information
Sep 28 18:50:58 nas kernel: ACPI: HPET id: 0xffffffff base: 0xfed00000
Sep 28 18:50:58 nas kernel: SMP: Allowing 4 CPUs, 0 hotplug CPUs
Sep 28 18:50:58 nas kernel: nr_irqs_gsi: 40
Sep 28 18:50:58 nas kernel: Allocating PCI resources starting at 40000000 (gap: 40000000:bee00000)
Sep 28 18:50:58 nas kernel: setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
Sep 28 18:50:58 nas kernel: PERCPU: Embedded 26 pages/cpu @ffff88003f200000 s73856 r8192 d24448 u524288
Sep 28 18:50:58 nas kernel: pcpu-alloc: s73856 r8192 d24448 u524288 alloc=1*2097152
Sep 28 18:50:58 nas kernel: pcpu-alloc: [0] 0 1 2 3
Sep 28 18:50:58 nas kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 256059
Sep 28 18:50:58 nas kernel: Kernel command line: console=ttyS0 hpet=disable initrd=initrd.gz reason=normal BOOT_IMAGE=kernel
Sep 28 18:50:58 nas kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Sep 28 18:50:58 nas kernel: Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Sep 28 18:50:58 nas kernel: Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Sep 28 18:50:58 nas kernel: Memory: 1010840k/1038912k available (5851k kernel code, 464k absent, 27608k reserved, 2835k data, 400k init)
Sep 28 18:50:58 nas kernel: SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Sep 28 18:50:58 nas kernel: Hierarchical RCU implementation.
Sep 28 18:50:58 nas kernel: ^IRCU-based detection of stalled CPUs is disabled.
Sep 28 18:50:58 nas kernel: NR_IRQS:512
Sep 28 18:50:58 nas kernel: Console: colour VGA+ 80x25
Sep 28 18:50:58 nas kernel: console [ttyS0] enabled
Sep 28 18:50:58 nas kernel: Fast TSC calibration failed
Sep 28 18:50:58 nas kernel: TSC: PIT calibration matches PMTIMER. 1 loops
Sep 28 18:50:58 nas kernel: Detected 1662.465 MHz processor.
Sep 28 18:50:58 nas kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 3324.93 BogoMIPS (lpj=1662465)
Sep 28 18:50:58 nas kernel: pid_max: default: 32768 minimum: 301
Sep 28 18:50:58 nas kernel: Mount-cache hash table entries: 256
Sep 28 18:50:58 nas kernel: Initializing cgroup subsys blkio
Sep 28 18:50:58 nas kernel: CPU: Physical Processor ID: 0
Sep 28 18:50:58 nas kernel: CPU: Processor Core ID: 0
Sep 28 18:50:58 nas kernel: mce: CPU supports 5 MCE banks
Sep 28 18:50:58 nas kernel: CPU0: Thermal monitoring enabled (TM1)
Sep 28 18:50:58 nas kernel: using mwait in idle threads.
Sep 28 18:50:58 nas kernel: Performance Events: PEBS fmt0+, Atom events, Intel PMU driver.
Sep 28 18:50:58 nas kernel: ... version: 3
Sep 28 18:50:58 nas kernel: ... bit width: 40
Sep 28 18:50:58 nas kernel: ... generic registers: 2
Sep 28 18:50:58 nas kernel: ... value mask: 000000ffffffffff
Sep 28 18:50:58 nas kernel: ... max period: 000000007fffffff
Sep 28 18:50:58 nas kernel: ... fixed-purpose events: 3
Sep 28 18:50:58 nas kernel: ... event mask: 0000000700000003
Sep 28 18:50:58 nas kernel: ACPI: Core revision 20101013
Sep 28 18:50:58 nas kernel: Setting APIC routing to flat
Sep 28 18:50:58 nas kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Sep 28 18:50:58 nas kernel: CPU0: Intel(R) Atom(TM) CPU D510 @ 1.66GHz stepping 0a
Sep 28 18:50:58 nas kernel: Booting Node 0, Processors #1 #2 #3 Ok.
Sep 28 18:50:58 nas kernel: Brought up 4 CPUs
Sep 28 18:50:58 nas kernel: Total of 4 processors activated (13298.50 BogoMIPS).
Sep 28 18:50:58 nas kernel: xor: automatically using best checksumming function: generic_sse
Sep 28 18:50:58 nas kernel: generic_sse: 5056.000 MB/sec
Sep 28 18:50:58 nas kernel: xor: using function: generic_sse (5056.000 MB/sec)
Sep 28 18:50:58 nas kernel: NET: Registered protocol family 16
Sep 28 18:50:58 nas kernel: ACPI: bus type pci registered
Sep 28 18:50:58 nas kernel: dca service started, version 1.12.1
Sep 28 18:50:58 nas kernel: PCI: Using configuration type 1 for base access
Sep 28 18:50:58 nas kernel: bio: create slab <bio-0> at 0
Sep 28 18:50:58 nas kernel: raid6: int64x1 371 MB/s
Sep 28 18:50:58 nas kernel: raid6: int64x2 574 MB/s
Sep 28 18:50:58 nas kernel: raid6: int64x4 574 MB/s
Sep 28 18:50:58 nas kernel: raid6: int64x8 687 MB/s
Sep 28 18:50:58 nas kernel: raid6: sse2x1 621 MB/s
Sep 28 18:50:58 nas kernel: raid6: sse2x2 1136 MB/s
Sep 28 18:50:58 nas kernel: raid6: sse2x4 2003 MB/s
Sep 28 18:50:58 nas kernel: raid6: using algorithm sse2x4 (2003 MB/s)
Sep 28 18:50:58 nas kernel: ACPI: EC: Look up EC in DSDT
Sep 28 18:50:58 nas kernel: ACPI: Executed 1 blocks of module-level executable AML code
Sep 28 18:50:58 nas kernel: ACPI: Interpreter enabled
Sep 28 18:50:58 nas kernel: ACPI: (supports S0 S5)
Sep 28 18:50:58 nas kernel: ACPI: Using IOAPIC for interrupt routing
Sep 28 18:50:58 nas kernel: ACPI Exception: AE_NOT_FOUND, Evaluating _PRW (20101013/scan-723)
Sep 28 18:50:58 nas kernel: ACPI: No dock devices found.
Sep 28 18:50:58 nas kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Sep 28 18:50:58 nas kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Sep 28 18:50:58 nas kernel: pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
Sep 28 18:50:58 nas kernel: pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
Sep 28 18:50:58 nas kernel: pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
Sep 28 18:50:58 nas kernel: pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff]
Sep 28 18:50:58 nas kernel: pci_root PNP0A08:00: host bridge window [mem 0x3f700000-0xdfffffff]
Sep 28 18:50:58 nas kernel: pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xfed8ffff]
Sep 28 18:50:58 nas kernel: pci 0000:00:00.0: [8086:a000] type 0 class 0x000600
Sep 28 18:50:58 nas kernel: pci 0000:00:02.0: [8086:a001] type 0 class 0x000300
Sep 28 18:50:58 nas kernel: pci 0000:00:02.0: reg 10: [mem 0xfe880000-0xfe8fffff]
Sep 28 18:50:58 nas kernel: pci 0000:00:02.0: reg 14: [io 0xcc00-0xcc07]
Sep 28 18:50:58 nas kernel: pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
Sep 28 18:50:58 nas kernel: pci 0000:00:02.0: reg 1c: [mem 0xfe900000-0xfe9fffff]
Sep 28 18:50:58 nas kernel: pci 0000:00:02.1: [8086:a002] type 0 class 0x000380
Sep 28 18:50:58 nas kernel: pci 0000:00:02.1: reg 10: [mem 0xfe780000-0xfe7fffff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.0: [8086:2937] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.0: reg 20: [io 0xc880-0xc89f]
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.1: [8086:2938] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.1: reg 20: [io 0xc800-0xc81f]
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.2: [8086:2939] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.2: reg 20: [io 0xc480-0xc49f]
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.7: [8086:293c] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.7: reg 10: [mem 0xfe87bc00-0xfe87bfff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
Sep 28 18:50:58 nas kernel: pci 0000:00:1a.7: PME# disabled
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: [8086:2940] type 1 class 0x000604
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: PME# disabled
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: [8086:2942] type 1 class 0x000604
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: PME# disabled
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.0: [8086:2934] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.0: reg 20: [io 0xc400-0xc41f]
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.1: [8086:2935] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.1: reg 20: [io 0xc080-0xc09f]
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.2: [8086:2936] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.2: reg 20: [io 0xc000-0xc01f]
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.7: [8086:293a] type 0 class 0x000c03
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.7: reg 10: [mem 0xfe87b800-0xfe87bbff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
Sep 28 18:50:58 nas kernel: pci 0000:00:1d.7: PME# disabled
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.0: [8086:2916] type 0 class 0x000601
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0a00 (mask 00ff)
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: [8086:2922] type 0 class 0x000106
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: reg 10: [io 0xb400-0xb407]
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: reg 14: [io 0xbc00-0xbc03]
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: reg 18: [io 0xb880-0xb887]
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: reg 1c: [io 0xb800-0xb803]
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: reg 20: [io 0xb480-0xb49f]
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: reg 24: [mem 0xfe87b000-0xfe87b7ff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: PME# supported from D3hot
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.2: PME# disabled
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.3: [8086:2930] type 0 class 0x000c05
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.3: reg 10: [mem 0xfe87ac00-0xfe87acff 64bit]
Sep 28 18:50:58 nas kernel: pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
Sep 28 18:50:58 nas kernel: pci 0000:01:00.0: [11ab:4380] type 0 class 0x000200
Sep 28 18:50:58 nas kernel: pci 0000:01:00.0: reg 10: [mem 0xfeadc000-0xfeadffff 64bit]
Sep 28 18:50:58 nas kernel: pci 0000:01:00.0: reg 18: [io 0xd800-0xd8ff]
Sep 28 18:50:58 nas kernel: pci 0000:01:00.0: reg 30: [mem 0xfeae0000-0xfeafffff pref]
Sep 28 18:50:58 nas kernel: pci 0000:01:00.0: supports D1 D2
Sep 28 18:50:58 nas kernel: pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Sep 28 18:50:58 nas kernel: pci 0000:01:00.0: PME# disabled
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: PCI bridge to [bus 01-01]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: bridge window [io 0xd000-0xdfff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: bridge window [mem 0xfea00000-0xfeafffff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
Sep 28 18:50:58 nas kernel: pci 0000:02:00.0: [11ab:4380] type 0 class 0x000200
Sep 28 18:50:58 nas kernel: pci 0000:02:00.0: reg 10: [mem 0xfebdc000-0xfebdffff 64bit]
Sep 28 18:50:58 nas kernel: pci 0000:02:00.0: reg 18: [io 0xe800-0xe8ff]
Sep 28 18:50:58 nas kernel: pci 0000:02:00.0: reg 30: [mem 0xfebe0000-0xfebfffff pref]
Sep 28 18:50:58 nas kernel: pci 0000:02:00.0: supports D1 D2
Sep 28 18:50:58 nas kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Sep 28 18:50:58 nas kernel: pci 0000:02:00.0: PME# disabled
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: PCI bridge to [bus 02-02]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: bridge window [mem 0xfeb00000-0xfebfffff]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: PCI bridge to [bus 03-03] (subtractive decode)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [io 0xf000-0x0000] (disabled)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem 0xfff00000-0x000fffff] (disabled)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem 0x3f700000-0xdfffffff] (subtractive decode)
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfed8ffff] (subtractive decode)
Sep 28 18:50:58 nas kernel: pci_bus 0000:00: on NUMA node 0
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12 14 15)
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs *5)
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12 *14 15)
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 11 12 14 *15)
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled.
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 *11 12 14 15)
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled.
Sep 28 18:50:58 nas kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 6 *7 10 11 12 14 15)
Sep 28 18:50:58 nas kernel: SCSI subsystem initialized
Sep 28 18:50:58 nas kernel: libata version 3.00 loaded.
Sep 28 18:50:58 nas kernel: usbcore: registered new interface driver usbfs
Sep 28 18:50:58 nas kernel: usbcore: registered new interface driver hub
Sep 28 18:50:58 nas kernel: usbcore: registered new device driver usb
Sep 28 18:50:58 nas kernel: PCI: Using ACPI for IRQ routing
Sep 28 18:50:58 nas kernel: PCI: pci_cache_line_size set to 64 bytes
Sep 28 18:50:58 nas kernel: Expanded resource reserved due to conflict with PCI Bus 0000:00
Sep 28 18:50:58 nas kernel: reserve RAM buffer: 000000000009c800 - 000000000009ffff
Sep 28 18:50:58 nas kernel: reserve RAM buffer: 000000003f690000 - 000000003fffffff
Sep 28 18:50:58 nas kernel: Switching to clocksource tsc
Sep 28 18:50:58 nas kernel: pnp: PnP ACPI init
Sep 28 18:50:58 nas kernel: ACPI: bus type pnp registered
Sep 28 18:50:58 nas kernel: pnp 00:00: [bus 00-ff]
Sep 28 18:50:58 nas kernel: pnp 00:00: [io 0x0cf8-0x0cff]
Sep 28 18:50:58 nas kernel: pnp 00:00: [io 0x0000-0x0cf7 window]
Sep 28 18:50:58 nas kernel: pnp 00:00: [io 0x0d00-0xffff window]
Sep 28 18:50:58 nas kernel: pnp 00:00: [mem 0x000a0000-0x000bffff window]
Sep 28 18:50:58 nas kernel: pnp 00:00: [mem 0x000d0000-0x000dffff window]
Sep 28 18:50:58 nas kernel: pnp 00:00: [mem 0x3f700000-0xdfffffff window]
Sep 28 18:50:58 nas kernel: pnp 00:00: [mem 0xf0000000-0xfed8ffff window]
Sep 28 18:50:58 nas kernel: pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
Sep 28 18:50:58 nas kernel: pnp 00:01: [mem 0xfed14000-0xfed19fff]
Sep 28 18:50:58 nas kernel: pnp 00:01: [mem 0xfed90000-0xfed93fff]
Sep 28 18:50:58 nas kernel: pnp 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
Sep 28 18:50:58 nas kernel: pnp 00:02: [dma 4]
Sep 28 18:50:58 nas kernel: pnp 00:02: [io 0x0000-0x000f]
Sep 28 18:50:58 nas kernel: pnp 00:02: [io 0x0081-0x0083]
Sep 28 18:50:58 nas kernel: pnp 00:02: [io 0x0087]
Sep 28 18:50:58 nas kernel: pnp 00:02: [io 0x0089-0x008b]
Sep 28 18:50:58 nas kernel: pnp 00:02: [io 0x008f]
Sep 28 18:50:58 nas kernel: pnp 00:02: [io 0x00c0-0x00df]
Sep 28 18:50:58 nas kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
Sep 28 18:50:58 nas kernel: pnp 00:03: [io 0x0070-0x0071]
Sep 28 18:50:58 nas kernel: pnp 00:03: [irq 8]
Sep 28 18:50:58 nas kernel: pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
Sep 28 18:50:58 nas kernel: pnp 00:04: [io 0x0061]
Sep 28 18:50:58 nas kernel: pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
Sep 28 18:50:58 nas kernel: pnp 00:05: [io 0x00f0-0x00ff]
Sep 28 18:50:58 nas kernel: pnp 00:05: [irq 13]
Sep 28 18:50:58 nas kernel: pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
Sep 28 18:50:58 nas kernel: pnp 00:06: [io 0x03f8-0x03ff]
Sep 28 18:50:58 nas kernel: pnp 00:06: [irq 4]
Sep 28 18:50:58 nas kernel: pnp 00:06: [dma 0 disabled]
Sep 28 18:50:58 nas kernel: pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
Sep 28 18:50:58 nas kernel: pnp 00:07: [io 0x02f8-0x02ff]
Sep 28 18:50:58 nas kernel: pnp 00:07: [irq 3]
Sep 28 18:50:58 nas kernel: pnp 00:07: [dma 0 disabled]
Sep 28 18:50:58 nas kernel: pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
Sep 28 18:50:58 nas kernel: pnp 00:08: [io 0x0000-0xffffffffffffffff disabled]
Sep 28 18:50:58 nas kernel: pnp 00:08: [io 0x0a00-0x0a0f]
Sep 28 18:50:58 nas kernel: pnp 00:08: [io 0x0a10-0x0a1f]
Sep 28 18:50:58 nas kernel: pnp 00:08: [io 0x0a20-0x0a2f]
Sep 28 18:50:58 nas kernel: pnp 00:08: [io 0x0a30-0x0a3f]
Sep 28 18:50:58 nas kernel: pnp 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0010-0x001f]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0022-0x003f]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0044-0x005f]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0062-0x0063]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0065-0x006f]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0072-0x007f]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0080]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0084-0x0086]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0088]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x008c-0x008e]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0090-0x009f]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x00a2-0x00bf]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x00e0-0x00ef]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x04d0-0x04d1]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0800-0x087f]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0000-0xffffffffffffffff disabled]
Sep 28 18:50:58 nas kernel: pnp 00:09: [io 0x0480-0x04ff]
Sep 28 18:50:58 nas kernel: pnp 00:09: [mem 0xfed1c000-0xfed1ffff]
Sep 28 18:50:58 nas kernel: pnp 00:09: [mem 0xfed20000-0xfed3ffff]
Sep 28 18:50:58 nas kernel: pnp 00:09: [mem 0xfed40000-0xfed8ffff]
Sep 28 18:50:58 nas kernel: pnp 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 28 18:50:58 nas kernel: pnp 00:0a: [mem 0xfed00000-0xfed003ff]
Sep 28 18:50:58 nas kernel: pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active)
Sep 28 18:50:58 nas kernel: pnp 00:0b: [mem 0xffb00000-0xffbfffff]
Sep 28 18:50:58 nas kernel: pnp 00:0b: [mem 0xfff00000-0xffffffff]
Sep 28 18:50:58 nas kernel: pnp 00:0b: Plug and Play ACPI device, IDs INT0800 (active)
Sep 28 18:50:58 nas kernel: pnp 00:0c: [mem 0xffc00000-0xffefffff]
Sep 28 18:50:58 nas kernel: pnp 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 28 18:50:58 nas kernel: pnp 00:0d: [io 0x0060]
Sep 28 18:50:58 nas kernel: pnp 00:0d: [io 0x0064]
Sep 28 18:50:58 nas kernel: pnp 00:0d: [mem 0xfec00000-0xfec00fff]
Sep 28 18:50:58 nas kernel: pnp 00:0d: [mem 0xfee00000-0xfee00fff]
Sep 28 18:50:58 nas kernel: pnp 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 28 18:50:58 nas kernel: pnp 00:0e: [mem 0xe0000000-0xefffffff]
Sep 28 18:50:58 nas kernel: pnp 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 28 18:50:58 nas kernel: pnp 00:0f: [mem 0x00000000-0x0009ffff]
Sep 28 18:50:58 nas kernel: pnp 00:0f: [mem 0x000c0000-0x000cffff]
Sep 28 18:50:58 nas kernel: pnp 00:0f: [mem 0x000e0000-0x000fffff]
Sep 28 18:50:58 nas kernel: pnp 00:0f: [mem 0x00100000-0x3f6fffff]
Sep 28 18:50:58 nas kernel: pnp 00:0f: [mem 0xfed90000-0xffffffff]
Sep 28 18:50:58 nas kernel: pnp 00:0f: Plug and Play ACPI device, IDs PNP0c01 (active)
Sep 28 18:50:58 nas kernel: pnp: PnP ACPI: found 16 devices
Sep 28 18:50:58 nas kernel: ACPI: ACPI bus type pnp unregistered
Sep 28 18:50:58 nas kernel: system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:01: [mem 0xfed90000-0xfed93fff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:08: [io 0x0a00-0x0a0f] has been reserved
Sep 28 18:50:58 nas kernel: system 00:08: [io 0x0a10-0x0a1f] has been reserved
Sep 28 18:50:58 nas kernel: system 00:08: [io 0x0a20-0x0a2f] has been reserved
Sep 28 18:50:58 nas kernel: system 00:08: [io 0x0a30-0x0a3f] has been reserved
Sep 28 18:50:58 nas kernel: system 00:09: [io 0x04d0-0x04d1] has been reserved
Sep 28 18:50:58 nas kernel: system 00:09: [io 0x0800-0x087f] has been reserved
Sep 28 18:50:58 nas kernel: system 00:09: [io 0x0480-0x04ff] could not be reserved
Sep 28 18:50:58 nas kernel: system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:09: [mem 0xfed40000-0xfed8ffff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:0c: [mem 0xffc00000-0xffefffff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved
Sep 28 18:50:58 nas kernel: system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:0e: [mem 0xe0000000-0xefffffff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:0f: [mem 0x00000000-0x0009ffff] could not be reserved
Sep 28 18:50:58 nas kernel: system 00:0f: [mem 0x000c0000-0x000cffff] has been reserved
Sep 28 18:50:58 nas kernel: system 00:0f: [mem 0x000e0000-0x000fffff] could not be reserved
Sep 28 18:50:58 nas kernel: system 00:0f: [mem 0x00100000-0x3f6fffff] could not be reserved
Sep 28 18:50:58 nas kernel: system 00:0f: [mem 0xfed90000-0xffffffff] could not be reserved
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: BAR 9: assigned [mem 0x40000000-0x401fffff 64bit pref]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: BAR 9: assigned [mem 0x40200000-0x403fffff 64bit pref]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: bridge window [mem 0x40000000-0x401fffff 64bit pref]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: bridge window [mem 0x40200000-0x403fffff 64bit pref]
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [io disabled]
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem disabled]
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: bridge window [mem pref disabled]
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.0: setting latency timer to 64
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
Sep 28 18:50:58 nas kernel: pci 0000:00:1c.1: setting latency timer to 64
Sep 28 18:50:58 nas kernel: pci 0000:00:1e.0: setting latency timer to 64
Sep 28 18:50:58 nas kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
Sep 28 18:50:58 nas kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:00: resource 8 [mem 0x3f700000-0xdfffffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfed8ffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:01: resource 1 [mem 0xfea00000-0xfeafffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:01: resource 2 [mem 0x40000000-0x401fffff 64bit pref]
Sep 28 18:50:58 nas kernel: pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:02: resource 1 [mem 0xfeb00000-0xfebfffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:02: resource 2 [mem 0x40200000-0x403fffff 64bit pref]
Sep 28 18:50:58 nas kernel: pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
Sep 28 18:50:58 nas kernel: pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000dffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:03: resource 8 [mem 0x3f700000-0xdfffffff]
Sep 28 18:50:58 nas kernel: pci_bus 0000:03: resource 9 [mem 0xf0000000-0xfed8ffff]
Sep 28 18:50:58 nas kernel: NET: Registered protocol family 2
Sep 28 18:50:58 nas kernel: IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
Sep 28 18:50:58 nas kernel: TCP established hash table entries: 131072 (order: 9, 2097152 bytes)
Sep 28 18:50:58 nas kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Sep 28 18:50:58 nas kernel: TCP: Hash tables configured (established 131072 bind 65536)
Sep 28 18:50:58 nas kernel: TCP reno registered
Sep 28 18:50:58 nas kernel: UDP hash table entries: 512 (order: 2, 16384 bytes)
Sep 28 18:50:58 nas kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Sep 28 18:50:58 nas kernel: RPC: Registered udp transport module.
Sep 28 18:50:58 nas kernel: RPC: Registered tcp transport module.
Sep 28 18:50:58 nas kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Sep 28 18:50:58 nas kernel: pci 0000:00:02.0: Boot video device
Sep 28 18:50:58 nas kernel: PCI: CLS 32 bytes, default 64
Sep 28 18:50:58 nas kernel: Unpacking initramfs...
Sep 28 18:50:58 nas kernel: Freeing initrd memory: 1552k freed
Sep 28 18:50:58 nas kernel: VFS: Disk quotas dquot_6.5.2
Sep 28 18:50:58 nas kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Sep 28 18:50:58 nas kernel: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Sep 28 18:50:58 nas kernel: fuse init (API version 7.15)
Sep 28 18:50:58 nas kernel: Btrfs loaded
Sep 28 18:50:58 nas kernel: msgmni has been set to 1977
Sep 28 18:50:58 nas kernel: async_tx: api initialized (async)
Sep 28 18:50:58 nas kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Sep 28 18:50:58 nas kernel: io scheduler noop registered
Sep 28 18:50:58 nas kernel: io scheduler deadline registered
Sep 28 18:50:58 nas kernel: io scheduler cfq registered (default)
Sep 28 18:50:58 nas kernel: pcieport 0000:00:1c.0: ACPI _OSC control granted for 0x14
Sep 28 18:50:58 nas kernel: pcieport 0000:00:1c.0: setting latency timer to 64
Sep 28 18:50:58 nas kernel: pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
Sep 28 18:50:58 nas kernel: pcieport 0000:00:1c.1: ACPI _OSC control granted for 0x14
Sep 28 18:50:58 nas kernel: pcieport 0000:00:1c.1: setting latency timer to 64
Sep 28 18:50:58 nas kernel: pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
Sep 28 18:50:58 nas kernel: input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
Sep 28 18:50:58 nas kernel: ACPI: Power Button [PWRB]
Sep 28 18:50:58 nas kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Sep 28 18:50:58 nas kernel: ACPI: Power Button [PWRF]
Sep 28 18:50:58 nas kernel: ACPI: acpi_idle registered with cpuidle
Sep 28 18:50:58 nas kernel: Linux agpgart interface v0.103
Sep 28 18:50:58 nas kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Sep 28 18:50:58 nas kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Sep 28 18:50:58 nas kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Sep 28 18:50:58 nas kernel: 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Sep 28 18:50:58 nas kernel: 00:07: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Sep 28 18:50:58 nas kernel: loop: module loaded
Sep 28 18:50:58 nas kernel: mpt2sas version 06.100.00.00 loaded
Sep 28 18:50:58 nas kernel: ahci 0000:00:1f.2: version 3.0
Sep 28 18:50:58 nas kernel: ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
Sep 28 18:50:58 nas kernel: ahci 0000:00:1f.2: irq 42 for MSI/MSI-X
Sep 28 18:50:58 nas kernel: ahci: SSS flag set, parallel bus scan disabled
Sep 28 18:50:58 nas kernel: ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
Sep 28 18:50:58 nas kernel: ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ccc ems sxs
Sep 28 18:50:58 nas kernel: ahci 0000:00:1f.2: setting latency timer to 64
Sep 28 18:50:58 nas kernel: scsi0 : ahci
Sep 28 18:50:58 nas kernel: scsi1 : ahci
Sep 28 18:50:58 nas kernel: scsi2 : ahci
Sep 28 18:50:58 nas kernel: scsi3 : ahci
Sep 28 18:50:58 nas kernel: scsi4 : ahci
Sep 28 18:50:58 nas kernel: scsi5 : ahci
Sep 28 18:50:58 nas kernel: ata1: SATA max UDMA/133 abar m2048@0xfe87b000 port 0xfe87b100 irq 42
Sep 28 18:50:58 nas kernel: ata2: SATA max UDMA/133 abar m2048@0xfe87b000 port 0xfe87b180 irq 42
Sep 28 18:50:58 nas kernel: ata3: SATA max UDMA/133 abar m2048@0xfe87b000 port 0xfe87b200 irq 42
Sep 28 18:50:58 nas kernel: ata4: SATA max UDMA/133 abar m2048@0xfe87b000 port 0xfe87b280 irq 42
Sep 28 18:50:58 nas kernel: ata5: SATA max UDMA/133 abar m2048@0xfe87b000 port 0xfe87b300 irq 42
Sep 28 18:50:58 nas kernel: ata6: SATA max UDMA/133 abar m2048@0xfe87b000 port 0xfe87b380 irq 42
Sep 28 18:50:58 nas kernel: e1000e: Intel(R) PRO/1000 Network Driver - 1.2.7-k2
Sep 28 18:50:58 nas kernel: e1000e: Copyright (c) 1999 - 2010 Intel Corporation.
Sep 28 18:50:58 nas kernel: Intel(R) Gigabit Ethernet Network Driver - version 2.1.0-k2
Sep 28 18:50:58 nas kernel: Copyright (c) 2007-2009 Intel Corporation.
Sep 28 18:50:58 nas kernel: ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 2.0.84-k2
Sep 28 18:50:58 nas kernel: ixgbe: Copyright (c) 1999-2010 Intel Corporation.
Sep 28 18:50:58 nas kernel: bonding: Ethernet Channel Bonding Driver: v3.7.0 (June 2, 2010)
Sep 28 18:50:58 nas kernel: bonding: Warning: either miimon or arp_interval and arp_ip_target module parameters must be specified, otherwise bonding will not detect link failures! see bonding.txt for details.
Sep 28 18:50:58 nas kernel: sk98lin 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Sep 28 18:50:58 nas kernel: sk98lin: Network Device Driver v10.70.1.3
Sep 28 18:50:58 nas kernel: (C)Copyright 1999-2008 Marvell(R).
Sep 28 18:50:58 nas kernel: sk98lin 0000:01:00.0: setting latency timer to 64
Sep 28 18:50:58 nas kernel: eth0: Marvell Yukon 88E8057 Gigabit Ethernet Controller
Sep 28 18:50:58 nas kernel: PrefPort:A RlmtMode:Check Link State
Sep 28 18:50:58 nas kernel: sk98lin 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
Sep 28 18:50:58 nas kernel: sk98lin 0000:02:00.0: setting latency timer to 64
Sep 28 18:50:58 nas kernel: eth1: Marvell Yukon 88E8057 Gigabit Ethernet Controller
Sep 28 18:50:58 nas kernel: tun: Universal TUN/TAP device driver, 1.6
Sep 28 18:50:58 nas kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Sep 28 18:50:58 nas kernel: Fusion MPT base driver 3.04.17
Sep 28 18:50:58 nas kernel: Copyright (c) 1999-2008 LSI Corporation
Sep 28 18:50:58 nas kernel: Fusion MPT SAS Host driver 3.04.17
Sep 28 18:50:58 nas kernel: Fusion MPT misc device (ioctl) driver 3.04.17
Sep 28 18:50:58 nas kernel: mptctl: Registered with Fusion MPT base driver
Sep 28 18:50:58 nas kernel: mptctl: /dev/mptctl @ (major,minor=10,220)
Sep 28 18:50:58 nas kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: setting latency timer to 64
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: EHCI Host Controller
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: debug port 1
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfe87bc00
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
Sep 28 18:50:58 nas kernel: hub 1-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 1-0:1.0: 6 ports detected
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: setting latency timer to 64
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: debug port 1
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfe87b800
Sep 28 18:50:58 nas kernel: ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
Sep 28 18:50:58 nas kernel: hub 2-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 2-0:1.0: 6 ports detected
Sep 28 18:50:58 nas kernel: uhci_hcd: USB Universal Host Controller Interface driver
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.0: setting latency timer to 64
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.0: UHCI Host Controller
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000c880
Sep 28 18:50:58 nas kernel: hub 3-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 3-0:1.0: 2 ports detected
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.1: setting latency timer to 64
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.1: UHCI Host Controller
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000c800
Sep 28 18:50:58 nas kernel: hub 4-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 4-0:1.0: 2 ports detected
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.2: PCI INT D -> GSI 19 (level, low) -> IRQ 19
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.2: setting latency timer to 64
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.2: UHCI Host Controller
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000c480
Sep 28 18:50:58 nas kernel: hub 5-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 5-0:1.0: 2 ports detected
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.0: setting latency timer to 64
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000c400
Sep 28 18:50:58 nas kernel: hub 6-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 6-0:1.0: 2 ports detected
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.1: setting latency timer to 64
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000c080
Sep 28 18:50:58 nas kernel: hub 7-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 7-0:1.0: 2 ports detected
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.2: setting latency timer to 64
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
Sep 28 18:50:58 nas kernel: uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c000
Sep 28 18:50:58 nas kernel: hub 8-0:1.0: USB hub found
Sep 28 18:50:58 nas kernel: hub 8-0:1.0: 2 ports detected
Sep 28 18:50:58 nas kernel: usbcore: registered new interface driver usblp
Sep 28 18:50:58 nas kernel: usbcore: registered new interface driver uas
Sep 28 18:50:58 nas kernel: Initializing USB Mass Storage driver...
Sep 28 18:50:58 nas kernel: usbcore: registered new interface driver usb-storage
Sep 28 18:50:58 nas kernel: USB Mass Storage support registered.
Sep 28 18:50:58 nas kernel: rtc_cmos 00:03: RTC can wake from S4
Sep 28 18:50:58 nas kernel: rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Sep 28 18:50:58 nas kernel: rtc0: alarms up to one month, y3k, 114 bytes nvram
Sep 28 18:50:58 nas kernel: i2c /dev entries driver
Sep 28 18:50:58 nas kernel: i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Sep 28 18:50:58 nas kernel: coretemp coretemp.0: Unable to read TjMax from CPU.
Sep 28 18:50:58 nas kernel: coretemp coretemp.0: Using relative temperature scale!
Sep 28 18:50:58 nas kernel: coretemp coretemp.1: Unable to read TjMax from CPU.
Sep 28 18:50:58 nas kernel: coretemp coretemp.1: Using relative temperature scale!
Sep 28 18:50:58 nas kernel: it87: Found IT8721F chip at 0xa10, revision 1
Sep 28 18:50:58 nas kernel: it87: in3 is VCC (+5V)
Sep 28 18:50:58 nas kernel: it87: in7 is VCCH (+5V Stand-By)
Sep 28 18:50:58 nas kernel: it87: Ultra 6: 87
Sep 28 18:50:58 nas kernel: md: raid0 personality registered for level 0
Sep 28 18:50:58 nas kernel: md: raid1 personality registered for level 1
Sep 28 18:50:58 nas kernel: md: raid10 personality registered for level 10
Sep 28 18:50:58 nas kernel: md: raid6 personality registered for level 6
Sep 28 18:50:58 nas kernel: md: raid5 personality registered for level 5
Sep 28 18:50:58 nas kernel: md: raid4 personality registered for level 4
Sep 28 18:50:58 nas kernel: device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
Sep 28 18:50:58 nas kernel: cpuidle: using governor ladder
Sep 28 18:50:58 nas kernel: cpuidle: using governor menu
Sep 28 18:50:58 nas kernel: ioatdma: Intel(R) QuickData Technology Driver 4.00
Sep 28 18:50:58 nas kernel: usbcore: registered new interface driver usbhid
Sep 28 18:50:58 nas kernel: usbhid: USB HID core driver
Sep 28 18:50:58 nas kernel: IPv4 over IPv4 tunneling driver
Sep 28 18:50:58 nas kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Sep 28 18:50:58 nas kernel: TCP bic registered
Sep 28 18:50:58 nas kernel: NET: Registered protocol family 10
Sep 28 18:50:58 nas kernel: lo: Disabled Privacy Extensions
Sep 28 18:50:58 nas kernel: tunl0: Disabled Privacy Extensions
Sep 28 18:50:58 nas kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Sep 28 18:50:58 nas kernel: NET: Registered protocol family 17
Sep 28 18:50:58 nas kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Sep 28 18:50:58 nas kernel: All bugs added by David S. Miller <davem@redhat.com>
Sep 28 18:50:58 nas kernel: Registering the dns_resolver key type
Sep 28 18:50:58 nas kernel: rtc_cmos 00:03: setting system clock to 2012-09-29 01:50:29 UTC (1348883429)
Sep 28 18:50:58 nas kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Sep 28 18:50:58 nas kernel: ata1.00: ATA-8: ST32000542AS, CC34, max UDMA/133
Sep 28 18:50:58 nas kernel: ata1.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Sep 28 18:50:58 nas kernel: ata1.00: configured for UDMA/133
Sep 28 18:50:58 nas kernel: scsi 0:0:0:0: Direct-Access ATA ST32000542AS CC34 PQ: 0 ANSI: 5
Sep 28 18:50:58 nas kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Sep 28 18:50:58 nas kernel: sd 0:0:0:0: [sda] Write Protect is off
Sep 28 18:50:58 nas kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Sep 28 18:50:58 nas kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Sep 28 18:50:58 nas kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 18:50:58 nas kernel: sda: sda1 sda2 sda5
Sep 28 18:50:58 nas kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Sep 28 18:50:58 nas kernel: usb 2-1: new high speed USB device using ehci_hcd and address 2
Sep 28 18:50:58 nas kernel: scsi6 : usb-storage 2-1:1.0
Sep 28 18:50:58 nas kernel: usb 7-1: new full speed USB device using uhci_hcd and address 2
Sep 28 18:50:58 nas kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Sep 28 18:50:58 nas kernel: ata2.00: ATA-8: ST32000542AS, CC34, max UDMA/133
Sep 28 18:50:58 nas kernel: ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Sep 28 18:50:58 nas kernel: ata2.00: configured for UDMA/133
Sep 28 18:50:58 nas kernel: scsi 1:0:0:0: Direct-Access ATA ST32000542AS CC34 PQ: 0 ANSI: 5
Sep 28 18:50:58 nas kernel: sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Sep 28 18:50:58 nas kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Sep 28 18:50:58 nas kernel: sd 1:0:0:0: [sdb] Write Protect is off
Sep 28 18:50:58 nas kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Sep 28 18:50:58 nas kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 18:50:58 nas kernel: sdb: sdb1 sdb2 sdb5
Sep 28 18:50:58 nas kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Sep 28 18:50:58 nas kernel: generic-usb 0003:0764:0501.0001: hiddev0: USB HID v1.10 Device [CP1500PFCLCD CRCA102-3I1] on usb-0000:00:1d.1-1/input0
Sep 28 18:50:58 nas kernel: ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Sep 28 18:50:58 nas kernel: ata3.00: ATA-8: ST32000542AS, CC34, max UDMA/133
Sep 28 18:50:58 nas kernel: ata3.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Sep 28 18:50:58 nas kernel: ata3.00: configured for UDMA/133
Sep 28 18:50:58 nas kernel: scsi 2:0:0:0: Direct-Access ATA ST32000542AS CC34 PQ: 0 ANSI: 5
Sep 28 18:50:58 nas kernel: sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Sep 28 18:50:58 nas kernel: sd 2:0:0:0: Attached scsi generic sg2 type 0
Sep 28 18:50:58 nas kernel: sd 2:0:0:0: [sdc] Write Protect is off
Sep 28 18:50:58 nas kernel: sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Sep 28 18:50:58 nas kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 18:50:58 nas kernel: sdc: sdc1 sdc2 sdc5
Sep 28 18:50:58 nas kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
Sep 28 18:50:58 nas kernel: ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Sep 28 18:50:58 nas kernel: ata4.00: ATA-8: ST32000542AS, CC34, max UDMA/133
Sep 28 18:50:58 nas kernel: ata4.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Sep 28 18:50:58 nas kernel: ata4.00: configured for UDMA/133
Sep 28 18:50:58 nas kernel: scsi 3:0:0:0: Direct-Access ATA ST32000542AS CC34 PQ: 0 ANSI: 5
Sep 28 18:50:58 nas kernel: sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Sep 28 18:50:58 nas kernel: sd 3:0:0:0: Attached scsi generic sg3 type 0
Sep 28 18:50:58 nas kernel: sd 3:0:0:0: [sdd] Write Protect is off
Sep 28 18:50:58 nas kernel: sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
Sep 28 18:50:58 nas kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 18:50:58 nas kernel: sdd: sdd1 sdd2 sdd5
Sep 28 18:50:58 nas kernel: sd 3:0:0:0: [sdd] Attached SCSI disk
Sep 28 18:50:58 nas kernel: ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Sep 28 18:50:58 nas kernel: ata5.00: ATA-8: ST32000542AS, CC34, max UDMA/133
Sep 28 18:50:58 nas kernel: ata5.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Sep 28 18:50:58 nas kernel: ata5.00: configured for UDMA/133
Sep 28 18:50:58 nas kernel: scsi 4:0:0:0: Direct-Access ATA ST32000542AS CC34 PQ: 0 ANSI: 5
Sep 28 18:50:58 nas kernel: sd 4:0:0:0: [sde] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Sep 28 18:50:58 nas kernel: sd 4:0:0:0: Attached scsi generic sg4 type 0
Sep 28 18:50:58 nas kernel: sd 4:0:0:0: [sde] Write Protect is off
Sep 28 18:50:58 nas kernel: sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
Sep 28 18:50:58 nas kernel: sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 18:50:58 nas kernel: sde: sde1 sde2 sde5
Sep 28 18:50:58 nas kernel: sd 4:0:0:0: [sde] Attached SCSI disk
Sep 28 18:50:58 nas kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Sep 28 18:50:58 nas kernel: ata6.00: ATA-8: ST32000542AS, CC34, max UDMA/133
Sep 28 18:50:58 nas kernel: ata6.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Sep 28 18:50:58 nas kernel: ata6.00: configured for UDMA/133
Sep 28 18:50:58 nas kernel: scsi 5:0:0:0: Direct-Access ATA ST32000542AS CC34 PQ: 0 ANSI: 5
Sep 28 18:50:58 nas kernel: sd 5:0:0:0: [sdf] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Sep 28 18:50:58 nas kernel: sd 5:0:0:0: Attached scsi generic sg5 type 0
Sep 28 18:50:58 nas kernel: sd 5:0:0:0: [sdf] Write Protect is off
Sep 28 18:50:58 nas kernel: sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00
Sep 28 18:50:58 nas kernel: sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 18:50:58 nas kernel: sdf: sdf1 sdf2 sdf5
Sep 28 18:50:58 nas kernel: sd 5:0:0:0: [sdf] Attached SCSI disk
Sep 28 18:50:58 nas kernel: Freeing unused kernel memory: 400k freed
Sep 28 18:50:58 nas kernel: nv6vpd: module license 'Proprietary' taints kernel.
Sep 28 18:50:58 nas kernel: Disabling lock debugging due to kernel taint
Sep 28 18:50:58 nas kernel: ReadyNAS VPD device driver init...
Sep 28 18:50:58 nas kernel: DMI Product Version: 06/10/2010 FLAME6-2 V1.1
Sep 28 18:50:58 nas kernel: month = 6 day = 10 year = 2010 name = FLAME6-2 major = 1 minor = 1
Sep 28 18:50:58 nas kernel: core = 0 data = 0 model = 0
Sep 28 18:50:58 nas kernel: scsi 6:0:0:0: Direct-Access SMI USB DISK 1100 PQ: 0 ANSI: 0 CCS
Sep 28 18:50:58 nas kernel: scsi: killing requests for dead queue
Sep 28 18:50:58 nas last message repeated 7 times
Sep 28 18:50:58 nas kernel: sd 6:0:0:0: Attached scsi generic sg6 type 0
Sep 28 18:50:58 nas kernel: sd 6:0:0:0: [sdg] 250880 512-byte logical blocks: (128 MB/122 MiB)
Sep 28 18:50:58 nas kernel: sd 6:0:0:0: [sdg] Write Protect is off
Sep 28 18:50:58 nas kernel: sd 6:0:0:0: [sdg] Mode Sense: 43 00 00 00
Sep 28 18:50:58 nas kernel: sd 6:0:0:0: [sdg] Assuming drive cache: write through
Sep 28 18:50:58 nas kernel: sdg: sdg1
Sep 28 18:50:58 nas kernel: sd 6:0:0:0: [sdg] Attached SCSI removable disk
Sep 28 18:50:58 nas kernel: nv6lcd v2.1 loaded.
Sep 28 18:50:58 nas kernel: pvgpio v1.0: initialization complete (systype:2)
Sep 28 18:50:58 nas kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sep 28 18:50:58 nas kernel: ADDRCONF(NETDEV_UP): eth1: link is not ready
Sep 28 18:50:58 nas kernel: md: bind<sdb1>
Sep 28 18:50:58 nas kernel: md: bind<sdc1>
Sep 28 18:50:58 nas kernel: md: bind<sdd1>
Sep 28 18:50:58 nas kernel: md: bind<sde1>
Sep 28 18:50:58 nas kernel: md: bind<sdf1>
Sep 28 18:50:58 nas kernel: md: bind<sda1>
Sep 28 18:50:58 nas kernel: bio: create slab <bio-1> at 1
Sep 28 18:50:58 nas kernel: md/raid1:md0: active with 6 out of 6 mirrors
Sep 28 18:50:58 nas kernel: md0: detected capacity change from 0 to 4293906432
Sep 28 18:50:58 nas kernel: md0: unknown partition table
Sep 28 18:50:58 nas kernel: md: bind<sdb2>
Sep 28 18:50:58 nas kernel: md: bind<sdc2>
Sep 28 18:50:58 nas kernel: md: bind<sdd2>
Sep 28 18:50:58 nas kernel: md: bind<sde2>
Sep 28 18:50:58 nas kernel: md: bind<sdf2>
Sep 28 18:50:58 nas kernel: md: bind<sda2>
Sep 28 18:50:58 nas kernel: md/raid:md1: device sda2 operational as raid disk 0
Sep 28 18:50:58 nas kernel: md/raid:md1: device sdf2 operational as raid disk 5
Sep 28 18:50:58 nas kernel: md/raid:md1: device sde2 operational as raid disk 4
Sep 28 18:50:58 nas kernel: md/raid:md1: device sdd2 operational as raid disk 3
Sep 28 18:50:58 nas kernel: md/raid:md1: device sdc2 operational as raid disk 2
Sep 28 18:50:58 nas kernel: md/raid:md1: device sdb2 operational as raid disk 1
Sep 28 18:50:58 nas kernel: md/raid:md1: allocated 6372kB
Sep 28 18:50:58 nas kernel: md/raid:md1: raid level 6 active with 6 out of 6 devices, algorithm 2
Sep 28 18:50:58 nas kernel: RAID conf printout:
Sep 28 18:50:58 nas kernel: --- level:6 rd:6 wd:6
Sep 28 18:50:58 nas kernel: disk 0, o:1, dev:sda2
Sep 28 18:50:58 nas kernel: disk 1, o:1, dev:sdb2
Sep 28 18:50:58 nas kernel: disk 2, o:1, dev:sdc2
Sep 28 18:50:58 nas kernel: disk 3, o:1, dev:sdd2
Sep 28 18:50:58 nas kernel: disk 4, o:1, dev:sde2
Sep 28 18:50:58 nas kernel: disk 5, o:1, dev:sdf2
Sep 28 18:50:58 nas kernel: md1: detected capacity change from 0 to 2147221504
Sep 28 18:50:58 nas kernel: md1: unknown partition table
Sep 28 18:50:58 nas kernel: md: bind<sda5>
Sep 28 18:50:58 nas kernel: md: bind<sdc5>
Sep 28 18:50:58 nas kernel: md: bind<sdd5>
Sep 28 18:50:58 nas kernel: md: bind<sde5>
Sep 28 18:50:58 nas kernel: md: bind<sdf5>
Sep 28 18:50:58 nas kernel: md: bind<sdb5>
Sep 28 18:50:58 nas kernel: md: kicking non-fresh sda5 from array!
Sep 28 18:50:58 nas kernel: md: unbind<sda5>
Sep 28 18:50:58 nas kernel: md: export_rdev(sda5)
Sep 28 18:50:58 nas kernel: md/raid:md2: device sdb5 operational as raid disk 1
Sep 28 18:50:58 nas kernel: md/raid:md2: device sdf5 operational as raid disk 5
Sep 28 18:50:58 nas kernel: md/raid:md2: device sde5 operational as raid disk 4
Sep 28 18:50:58 nas kernel: md/raid:md2: device sdd5 operational as raid disk 3
Sep 28 18:50:58 nas kernel: md/raid:md2: device sdc5 operational as raid disk 2
Sep 28 18:50:58 nas kernel: md/raid:md2: allocated 6372kB
Sep 28 18:50:58 nas kernel: md/raid:md2: raid level 5 active with 5 out of 6 devices, algorithm 2
Sep 28 18:50:58 nas kernel: --- level:5 rd:6 wd:5
Sep 28 18:50:58 nas kernel: disk 1, o:1, dev:sdb5
Sep 28 18:50:58 nas kernel: disk 2, o:1, dev:sdc5
Sep 28 18:50:58 nas kernel: disk 3, o:1, dev:sdd5
Sep 28 18:50:58 nas kernel: disk 4, o:1, dev:sde5
Sep 28 18:50:58 nas kernel: disk 5, o:1, dev:sdf5
Sep 28 18:50:58 nas kernel: md2: detected capacity change from 0 to 9977816023040
Sep 28 18:50:58 nas kernel: md2: unknown partition table
Sep 28 18:50:58 nas kernel: EXT3-fs: barriers not enabled
Sep 28 18:50:58 nas kernel: kjournald starting. Commit interval 5 seconds
Sep 28 18:50:58 nas kernel: EXT3-fs (md0): mounted filesystem with ordered data mode
Sep 28 18:50:58 nas kernel: eth0: network connection up using port A
Sep 28 18:50:58 nas kernel: speed: 1000
Sep 28 18:50:58 nas kernel: autonegotiation: yes
Sep 28 18:50:58 nas kernel: duplex mode: full
Sep 28 18:50:58 nas kernel: flowctrl: symmetric
Sep 28 18:50:58 nas kernel: role: slave
Sep 28 18:50:58 nas kernel: irq moderation: disabled
Sep 28 18:50:58 nas kernel: tcp offload: enabled
Sep 28 18:50:58 nas kernel: scatter-gather: enabled
Sep 28 18:50:58 nas kernel: tx-checksum: enabled
Sep 28 18:50:58 nas kernel: rx-checksum: enabled
Sep 28 18:50:58 nas kernel: rx-polling: enabled
Sep 28 18:50:58 nas kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sep 28 18:50:58 nas kernel: EXT3-fs (md0): using internal journal
Sep 28 18:50:58 nas kernel: eth0: no IPv6 routers present
Sep 28 18:50:58 nas kernel: udevd version 125 started
Sep 28 18:50:58 nas kernel: Adding 2096892k swap on /dev/md1. Priority:-1 extents:1 across:2096892k
Sep 28 18:50:58 nas kernel: ata1: EH complete
Sep 28 18:50:58 nas kernel: ata2: EH complete
Sep 28 18:50:58 nas kernel: ata3: EH complete
Sep 28 18:50:58 nas kernel: ata4: EH complete
Sep 28 18:50:58 nas kernel: ata5: EH complete
Sep 28 18:50:58 nas kernel: ata6: EH complete
Sep 28 18:50:58 nas kernel: EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1
Sep 28 18:50:58 nas kernel: disk 0, o:1, dev:sda5
Sep 28 18:50:58 nas kernel: md: recovery of RAID array md2
Sep 28 18:50:58 nas kernel: md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
Sep 28 18:50:58 nas kernel: md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
Sep 28 18:50:58 nas kernel: md: using 128k window, over a total of 1948792192 blocks.
Sep 28 18:51:13 nas ifplugd(eth0)[2512]: ifplugd 0.28 initializing.
Sep 28 18:51:13 nas ifplugd(eth0)[2512]: Using interface eth0/00:1F:33:EA:96:E4 with driver <sk98lin> (version: 10.70.1.3 (01))
Sep 28 18:51:13 nas ifplugd(eth0)[2512]: Using detection mode: SIOCETHTOOL
Sep 28 18:51:13 nas ifplugd(eth0)[2512]: Initialization complete, link beat detected.
Sep 28 18:51:13 nas ifplugd(eth0)[2512]: Executing '/etc/ifplugd/ifplugd.action eth0 up'.
Sep 28 18:51:14 nas ifplugd(eth0)[2512]: client: 2514: old priority 0, new priority 0
Sep 28 18:51:14 nas ifplugd(eth0)[2512]: client: No udhcpc found running; none killed.
Sep 28 18:51:15 nas udhcpc[2519]: udhcpc (v1.18.4) started
Sep 28 18:51:15 nas ifplugd(eth0)[2512]: client: udhcpc (v1.18.4) started
Sep 28 18:51:15 nas udhcpc[2519]: Sending discover...
Sep 28 18:51:15 nas ifplugd(eth0)[2512]: client: Sending discover...
Sep 28 18:51:15 nas udhcpc[2519]: Sending select for 192.168.0.110...
Sep 28 18:51:15 nas ifplugd(eth0)[2512]: client: Sending select for 192.168.0.110...
Sep 28 18:51:16 nas udhcpc[2519]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 28 18:51:16 nas ifplugd(eth0)[2512]: client: Lease of 192.168.0.110 obtained, lease time 7200
Sep 28 18:51:21 nas ifplugd(eth0)[2512]: client: apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.0.110 for ServerName
Sep 28 18:51:29 nas ifplugd(eth0)[2512]: client: Stopping rsync daemon: rsync.
Sep 28 18:51:30 nas ifplugd(eth0)[2512]: client: Running ntpd to synchronize clock.
Sep 28 18:51:30 nas chronyd[2654]: chronyd version 1.24 starting
Sep 28 18:51:30 nas upnpd(eth0)[2665]: Listening on 192.168.0.110:50000
Sep 28 18:51:30 nas rsyncd[2664]: rsyncd version 3.0.9 starting, listening on port 873
Sep 28 18:51:30 nas chronyd[2654]: Initial txc.tick=10000 txc.freq=0 (0.00000000) txc.offset=0 => hz=100 shift_hz=7
Sep 28 18:51:30 nas chronyd[2654]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
Sep 28 18:51:30 nas chronyd[2654]: Linux kernel major=2 minor=6 patch=37
Sep 28 18:51:30 nas chronyd[2654]: calculated_freq_scale=1.00000000 freq_scale=1.00000000
Sep 28 18:51:31 nas chronyd[2654]: System's initial offset : 0.523357 seconds slow of true (slew)
Sep 28 18:51:31 nas ifplugd(eth0)[2512]: client: Starting rsync daemon: rsync.
Sep 28 18:51:32 nas ifplugd(eth0)[2512]: client: Starting plexserver
Sep 28 18:51:38 nas ifplugd(eth0)[2512]: Program executed successfully.
Sep 28 18:51:39 nas ifplugd(eth1)[2825]: ifplugd 0.28 initializing.
Sep 28 18:51:39 nas ifplugd(eth1)[2825]: Using interface eth1/00:1F:33:EA:96:E5 with driver <sk98lin> (version: 10.70.1.3 (01))
Sep 28 18:51:39 nas ifplugd(eth1)[2825]: Using detection mode: SIOCETHTOOL
Sep 28 18:51:39 nas ifplugd(eth1)[2825]: Initialization complete, link beat not detected.
Sep 28 18:51:43 nas RAIDiator: System is up.
Sep 28 18:51:50 nas kernel: sk98lin 0000:01:00.0: PME# enabled
Sep 28 18:51:50 nas kernel: sk98lin 0000:02:00.0: PME# enabled
Sep 28 18:52:08 nas syslogd 1.4.1#18: restart.
Sep 28 18:52:11 nas avahi-daemon[3429]: Found user 'avahi' (UID 20) and group 'avahi' (GID 20).
Sep 28 18:52:11 nas avahi-daemon[3429]: Successfully dropped root privileges.
Sep 28 18:52:11 nas avahi-daemon[3429]: avahi-daemon 0.6.23 starting up.
Sep 28 18:52:11 nas avahi-daemon[3429]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sep 28 18:52:11 nas avahi-daemon[3429]: Loading service file /etc/avahi/services/afp.service.
Sep 28 18:52:11 nas avahi-daemon[3429]: Loading service file /etc/avahi/services/frontview.service.
Sep 28 18:52:11 nas avahi-daemon[3429]: Loading service file /etc/avahi/services/readynas.service.
Sep 28 18:52:12 nas avahi-daemon[3429]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.110.
Sep 28 18:52:12 nas avahi-daemon[3429]: New relevant interface eth0.IPv4 for mDNS.
Sep 28 18:52:12 nas avahi-daemon[3429]: Network interface enumeration completed.
Sep 28 18:52:12 nas avahi-daemon[3429]: Registering new address record for 192.168.0.110 on eth0.IPv4.
Sep 28 18:52:12 nas avahi-daemon[3429]: Registering HINFO record with values 'X86_64'/'LINUX'.
Sep 28 18:52:13 nas avahi-daemon[3429]: Server startup complete. Host name is nas.local. Local service cookie is 150880404.
Sep 28 18:52:13 nas avahi-daemon[3429]: Service "ReadyNAS Discovery [nas]" (/etc/avahi/services/readynas.service) successfully established.
Sep 28 18:52:13 nas avahi-daemon[3429]: Service "FrontView on nas" (/etc/avahi/services/frontview.service) successfully established.
Sep 28 18:52:13 nas avahi-daemon[3429]: Service "nas (AFP)" (/etc/avahi/services/afp.service) successfully established.
Sep 28 18:52:14 nas ipwatchd[3447]: IPwatchD started
Sep 28 19:00:05 nas chronyd[2654]: Selected source 17.171.4.14
Sep 28 19:04:23 nas chronyd[2654]: Selected source 209.249.181.23
Sep 28 19:06:03 nas RAIDiator: Backup finished. [Job 002]
Sep 28 19:07:00 nas rsyncd[5651]: connect from miniduo1.home (192.168.0.103)
Sep 28 19:07:00 nas rsyncd[5651]: unknown module 'Projects' tried from miniduo1.home (192.168.0.103)
Sep 28 19:11:00 nas rsyncd[6113]: connect from miniduo1.home (192.168.0.103)
Sep 28 19:11:00 nas rsyncd[6113]: unknown module 'Music_Library' tried from miniduo1.home (192.168.0.103)
Sep 28 19:11:00 nas rsyncd[6114]: connect from miniduo1.home (192.168.0.103)
Sep 28 19:11:00 nas rsyncd[6114]: unknown module 'Music_Library' tried from miniduo1.home (192.168.0.103)
Sep 28 19:45:00 nas rsyncd[7215]: connect from miniduo1.home (192.168.0.103)
Sep 28 19:45:00 nas rsyncd[7215]: unknown module 'backup' tried from miniduo1.home (192.168.0.103)
Sep 28 19:51:16 nas udhcpc[2540]: Sending renew...
Sep 28 19:51:16 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 28 20:05:15 nas RAIDiator: Backup finished. [Job 003]
Sep 28 20:05:59 nas RAIDiator: Backup finished. [Job 002]
Sep 28 20:07:31 nas RAIDiator: Backup finished. [Job 004]
Sep 28 20:51:16 nas udhcpc[2540]: Sending renew...
Sep 28 20:51:17 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 28 21:06:36 nas RAIDiator: Backup finished. [Job 002]
Sep 28 21:51:17 nas udhcpc[2540]: Sending renew...
Sep 28 21:51:17 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 28 22:05:20 nas RAIDiator: Backup finished. [Job 003]
Sep 28 22:06:32 nas RAIDiator: Backup finished. [Job 002]
Sep 28 22:51:18 nas udhcpc[2540]: Sending renew...
Sep 28 22:51:18 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 28 23:05:39 nas RAIDiator: Backup finished. [Job 002]
Sep 28 23:51:19 nas udhcpc[2540]: Sending renew...
Sep 28 23:51:19 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 00:05:05 nas RAIDiator: Backup finished. [Job 003]
Sep 29 00:05:07 nas RAIDiator: Backup finished. [Job 005]
Sep 29 00:05:58 nas RAIDiator: Backup finished. [Job 001]
Sep 29 00:06:42 nas RAIDiator: Backup finished. [Job 002]
Sep 29 00:09:38 nas RAIDiator: Backup finished. [Job 004]
Sep 29 00:51:19 nas udhcpc[2540]: Sending renew...
Sep 29 00:51:19 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 01:06:48 nas RAIDiator: Backup finished. [Job 002]
Sep 29 01:51:20 nas udhcpc[2540]: Sending renew...
Sep 29 01:51:20 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 02:05:24 nas RAIDiator: Backup finished. [Job 003]
Sep 29 02:06:04 nas RAIDiator: Backup finished. [Job 002]
Sep 29 02:25:23 nas kernel: md: md2: recovery done.
Sep 29 02:25:23 nas kernel: RAID conf printout:
Sep 29 02:25:23 nas kernel: --- level:5 rd:6 wd:6
Sep 29 02:25:23 nas kernel: disk 0, o:1, dev:sda5
Sep 29 02:25:23 nas kernel: disk 1, o:1, dev:sdb5
Sep 29 02:25:23 nas kernel: disk 2, o:1, dev:sdc5
Sep 29 02:25:23 nas kernel: disk 3, o:1, dev:sdd5
Sep 29 02:25:23 nas kernel: disk 4, o:1, dev:sde5
Sep 29 02:25:23 nas kernel: disk 5, o:1, dev:sdf5
Sep 29 02:25:37 nas RAIDiator: RAID sync finished on volume C.
Sep 29 02:25:37 nas RAIDiator: RAID event detected. (nas) : RAID sync finished on volume C.\n\n[Sat Sep 29 02:25:33 PDT 2012]
Sep 29 02:51:21 nas udhcpc[2540]: Sending renew...
Sep 29 02:51:21 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 02:56:31 nas noflushd[2197]: Spinning down disks.
Sep 29 03:05:12 nas noflushd[2197]: Disks spinning up after 8 minutes.
Sep 29 03:06:02 nas RAIDiator: Backup finished. [Job 002]
Sep 29 03:20:36 nas noflushd[2197]: Spinning down disks.
Sep 29 03:23:12 nas noflushd[2197]: Disks spinning up after 2 minutes.
Sep 29 03:28:14 nas noflushd[2197]: Spinning down disks.
Sep 29 03:51:21 nas udhcpc[2540]: Sending renew...
Sep 29 03:51:21 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 04:05:16 nas noflushd[2197]: Disks spinning up after 37 minutes.
Sep 29 04:05:41 nas RAIDiator: Backup finished. [Job 003]
Sep 29 04:05:52 nas RAIDiator: Backup finished. [Job 002]
Sep 29 04:06:44 nas RAIDiator: Backup finished. [Job 004]
Sep 29 04:50:45 nas noflushd[2197]: Spinning down disks.
Sep 29 04:51:21 nas udhcpc[2540]: Sending renew...
Sep 29 04:51:21 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 04:51:36 nas noflushd[2197]: Disks spinning up after 0 minutes.
Sep 29 04:57:20 nas noflushd[2197]: Spinning down disks.
Sep 29 05:05:11 nas noflushd[2197]: Disks spinning up after 7 minutes.
Sep 29 05:06:32 nas RAIDiator: Backup finished. [Job 002]
Sep 29 05:22:12 nas noflushd[2197]: Spinning down disks.
Sep 29 05:23:13 nas noflushd[2197]: Disks spinning up after 1 minutes.
Sep 29 05:50:47 nas noflushd[2197]: Spinning down disks.
Sep 29 05:52:07 nas udhcpc[2540]: Sending renew...
Sep 29 05:52:07 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 05:52:18 nas noflushd[2197]: Disks spinning up after 1 minutes.
Sep 29 05:58:06 nas noflushd[2197]: Spinning down disks.
Sep 29 06:05:12 nas noflushd[2197]: Disks spinning up after 7 minutes.
Sep 29 06:05:30 nas RAIDiator: Backup finished. [Job 001]
Sep 29 06:05:30 nas RAIDiator: Backup finished. [Job 003]
Sep 29 06:06:04 nas RAIDiator: Backup finished. [Job 002]
Sep 29 06:25:13 nas syslogd 1.4.1#18: restart.
Sep 29 06:30:18 nas noflushd[2197]: Spinning down disks.
Sep 29 06:38:15 nas noflushd[2197]: Disks spinning up after 7 minutes.
Sep 29 06:45:52 nas noflushd[2197]: Spinning down disks.
Sep 29 06:52:13 nas noflushd[2197]: Disks spinning up after 6 minutes.
Sep 29 06:52:44 nas udhcpc[2540]: Sending renew...
Sep 29 06:52:44 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 07:05:33 nas RAIDiator: Backup finished. [Job 002]
Sep 29 07:07:01 nas rsyncd[28071]: connect from miniduo1.home (192.168.0.103)
Sep 29 07:07:01 nas rsyncd[28071]: unknown module 'Projects' tried from miniduo1.home (192.168.0.103)
Sep 29 07:24:11 nas noflushd[2197]: Spinning down disks.
Sep 29 07:24:17 nas noflushd[2197]: Disks spinning up after 0 minutes.
Sep 29 07:29:15 nas noflushd[2197]: Spinning down disks.
Sep 29 07:33:26 nas noflushd[2197]: Disks spinning up after 4 minutes.
Sep 29 07:44:02 nas noflushd[2197]: Spinning down disks.
Sep 29 07:45:00 nas rsyncd[28821]: connect from miniduo1.home (192.168.0.103)
Sep 29 07:45:00 nas rsyncd[28821]: unknown module 'backup' tried from miniduo1.home (192.168.0.103)
Sep 29 07:52:44 nas udhcpc[2540]: Sending renew...
Sep 29 07:52:44 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 08:05:13 nas noflushd[2197]: Disks spinning up after 21 minutes.
Sep 29 08:05:42 nas RAIDiator: Backup finished. [Job 003]
Sep 29 08:05:49 nas RAIDiator: Backup finished. [Job 002]
Sep 29 08:06:45 nas RAIDiator: Backup finished. [Job 004]
Sep 29 08:36:07 nas noflushd[2197]: Spinning down disks.
Sep 29 08:52:33 nas noflushd[2197]: Disks spinning up after 16 minutes.
Sep 29 08:52:44 nas udhcpc[2540]: Sending renew...
Sep 29 08:52:44 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 08:58:04 nas noflushd[2197]: Spinning down disks.
Sep 29 09:05:11 nas noflushd[2197]: Disks spinning up after 7 minutes.
Sep 29 09:06:28 nas RAIDiator: Backup finished. [Job 002]
Sep 29 09:36:16 nas noflushd[2197]: Spinning down disks.
Sep 29 09:38:12 nas noflushd[2197]: Disks spinning up after 1 minutes.
Sep 29 09:44:25 nas noflushd[2197]: Spinning down disks.
Sep 29 09:47:11 nas noflushd[2197]: Disks spinning up after 2 minutes.
Sep 29 09:52:52 nas udhcpc[2540]: Sending renew...
Sep 29 09:52:52 nas udhcpc[2540]: Lease of 192.168.0.110 obtained, lease time 7200
Sep 29 09:57:59 nas noflushd[2197]: Spinning down disks.
Sep 29 10:03:30 nas noflushd[2197]: Disks spinning up after 5 minutes.
