sandroid
Apr 21, 2016Aspirant
6.5.0-T338 load question
I recently upgraded my Pro Pioneer to the latest 6.5 beta, and I have notice the system idles at a load of 1.
This is odd for two reasons, one is that under 4.2.x (and 6.4.2 on my ultra 4) the load has always negligible, and two, the load isn't attributable to any process running.
~# top
top - 19:05:01 up 4 days, 7:58, 2 users, load average: 1.01, 1.03, 1.05
Tasks: 195 total, 1 running, 194 sleeping, 0 stopped, 0 zombie
%Cpu0 : 0.3 us, 0.0 sy, 0.0 ni, 99.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu1 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu2 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu3 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 8161504 total, 7824468 used, 337036 free, 1500 buffers
KiB Swap: 2094844 total, 0 used, 2094844 free, 7250452 cached
Now I have upgraded the CPU to a Q6600 so that maybe an issue, but I'm wondering if this is normal. My cpu has been running hotter than it did under 4.2, but I think that is because the fans are running much cooler than they did so I'm assumitg it would run cooler if I set the fan speed to cool.
I don't think I can do more troubleshooting without installing something like perf, but I don't want to push installing too much new software on the box. I'm assuming this is like the old readynas systems where you are generally OK install software as long as you don't overwrite the readynas specific packages.
Any insight would be appreciated, and great work on OS6 support on Legacy. The end result is very impressive!
It's an issue with the button driver, specific to ReadyNAS Pro. The kernel button worker is constantly in an uninterruptible sleep, which by definition raises the load average by 1 (even though it's not actually doing anything). I'll try to get it fixed.
- mdgm-ntgrNETGEAR Employee Retired
What about on 6.5.0-RC1?
Can you send in your logs (see the Sending Logs link in my sig)?- sandroidAspirant
Thanks mgdm, I wasn't aware of RC-1, but I still have the same issue. I sent my logs in hopefully we can make sense of it.
Thanks again,
Sander
- SkywalkerNETGEAR Expert
- whgmkeller1Aspirant
Hi there. Where do I find the download for OS 6.5.0 (RC2?) for Legacy?
I'm currently running OS 6.4.0 on my legacy Prop Pioneer Edition, and wpould like to be able to migrate to the Netgear Single Sign-On solution with OS 6.5.0.
Thanks !
Willem
Netherlands
https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-5-0-RC2/m-p/1059936#U1059936
Just grab the x86_64 version (312/ 314/...).
