KillerBob
May 05, 2016Aspirant
6.5 RC on Pioneer Pro?
I have been runnning 6.x on my Pioneer Pro for a long time, and the only problem I have is that ReadyCLOUD does not work (it did earlier on, but one of the FW upgrades broke it). I also have 6.4.2 on my Ultra 2, and here ReadyCLOUD works just fine - hence I know I am not doing something wrong in the setting up.
When I look at the Cloud tab in the Admin page, the ReadyCLOUD on/off is always off, though the ReadyDROP and ReadyNAS Remote is on. I try to turn ReadyCLOUD on, but all that happens is... nothing. I log into ReadyCLOUD and see both NASes, but only the Ultra is on.
So when I read that NetGear is delivering 6.5 just about now, I get a bit exited. So my question is; has anyone tried installing the RC2 FW on a legacy ReadyNAS? Will it work?
Your system is now showing the correct serial number. You should be able to enable ReadyCLOUD now.
- mdgm-ntgrNETGEAR Employee Retired
Is your serial number showing in the UI for the Pro the MAC address of eth0 or a 13-digit NETGEAR serial?
If it is the MAC address, is there a label on the back of the unit showing a 13-digit NETGEAR serial number?
