jamestx10
Mar 23, 2017Aspirant
6.6.1 on Ultra 6 Loses DNS lookup after a few days
I have my router configured as the DNS server in the network settings. It can reach the router fine but it fails to resolve addresses after a few days. I reboot the NAS and it is good to go again for...
Retired_Member
Mar 23, 2017Why not trying to run with a static ip-address on the nas for a few days and see, whether that helps.
jamestx10
The NAS IP is reserved in DHCP by the router
The DNS setting on the NAS is hard coded to point to the IP of the router
I would prefer to let my Router manage the IPs unless you have found that this would fix the DNS lookup issue?
- Retired_MemberMar 23, 2017
I share your preference. I cannot offer a solution. This is just a suggestion.
My idea is: Currently the router is responsible for assigning the ip address to the nas. Now it would be interesting to see, whether the problem continues after you take away that responsibility from the router and leave the nas with a fix ip address.
If that helps, you a) would have a temporay fix and b) could continue to research for something which gets you closer to your preferred configuration.
- jak0lantashMar 23, 2017Mentor
I would suggest the same thing... "for troubleshooting purposes".
Try to switch your NAS to static IP for now, and confirm if the issue still occurs or not. That would help narrowing down the root cause.
- jamestx10Mar 23, 2017Aspirant
I have changed it from DHCP to Static now.
