jamestx10
Mar 23, 2017Aspirant
6.6.1 on Ultra 6 Loses DNS lookup after a few days
I have my router configured as the DNS server in the network settings. It can reach the router fine but it fails to resolve addresses after a few days. I reboot the NAS and it is good to go again for...
jak0lantash
Mar 26, 2017Mentor
Firstly, you should download the logs, at least for reference.
If you want to check via SSH, you could try to:
- ping google.com
- ping 8.8.8.8
- ping your default gateway
- ping what's supposed to be the DNS server
- ping google.com
- ping 8.8.8.8
- jak0lantashMar 26, 2017Mentor
You can also dump the current status of all network connections:
for a_service in $(connmanctl services | awk '{ printf $3" " }'); do connmanctl services $a_service; done- jamestx10Mar 26, 2017Aspirant
This time the unit locked up so I had to reboot it. I set the IP back to DHCP. Running your other command I noticed that I had not updated my NTP address and that the 2nd ethernet connection had a router and DNS entry set that it cannot connect to. I have Eth1 directly connected to a PC with a cross over cable. I removed the router and DNS entries from that connection. I am wondering if that was the issue??? How are the network connections weighted? Which link will it try by default? I see they are both listed as favorite.
/net/connman/service/ethernet_001f33ea8125_cable Type = ethernet Security = [ ] State = ready Favorite = True Immutable = False AutoConnect = True Name = Wired Ethernet = [ Method=auto, Interface=eth0, Address=00:1F:33:EA:81:25, MTU=1500 ] IPv4 = [ Method=dhcp, Address=10.10.10.20, Netmask=255.255.255.0, Gateway=10.10.10.1 ] IPv4.Configuration = [ Method=dhcp ] IPv6 = [ ] IPv6.Configuration = [ Method=off ] Nameservers = [ 10.10.10.1 ] Nameservers.Configuration = [ ] Timeservers = [ 10.10.10.26, time-a.netgear.com, 10.10.10.1 ] Timeservers.Configuration = [ 10.10.10.26, time-a.netgear.com ] Routes = [ ] Routes.Configuration = [ ] Domains = [ NULEAF ] Domains.Configuration = [ ] Proxy = [ Method=direct ] Proxy.Configuration = [ ] Provider = [ ] /net/connman/service/ethernet_001f33ea8124_cable Type = ethernet Security = [ ] State = ready Favorite = True Immutable = False AutoConnect = True Name = Wired Ethernet = [ Method=auto, Interface=eth1, Address=00:1F:33:EA:81:24, MTU=1500 ] IPv4 = [ Method=manual, Address=10.101.1.3, Netmask=255.255.255.0 ] IPv4.Configuration = [ Method=manual, Address=10.101.1.3, Netmask=255.255.255.0 ] IPv6 = [ ] IPv6.Configuration = [ Method=off ] Nameservers = [ ] Nameservers.Configuration = [ ] Timeservers = [ 10.10.10.26, time-a.netgear.com ] Timeservers.Configuration = [ 10.10.10.26, time-a.netgear.com ] Routes = [ ] Routes.Configuration = [ ] Domains = [ ] Domains.Configuration = [ ] Proxy = [ Method=direct ] Proxy.Configuration = [ ] Provider = [ ]
Once I removed that Router and DNS entry from Eth1 I could no longer resolve DNS So it really seems like it wants to use that link
root@NAS:~# ping google.com ping: bad address 'google.com' root@NAS:~# ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes 64 bytes from 8.8.8.8: seq=0 ttl=46 time=9.523 ms 64 bytes from 8.8.8.8: seq=1 ttl=46 time=9.473 ms
So next I disconencted Eth1 and then I could ping again. Any ideas on how to have the two connections used but favor Eth0 for internet and DNS?
- jamestx10Mar 28, 2017Aspirant
Is there a service on the NAS I can restart that should correct this?
