chainlinc
Sep 13, 2017Guide
6.8.0 breaks FTP
After upgrading to OS6 6.8.0, scans from my Lexmark MX410de multi-function scanner fail if the .pdf file being written to is not altered within about 3 seconds. This is a new failure that did not exi...
- Oct 03, 2017
We traced the cause of the issue, and have posted our findings to the ProFTPD bugzilla report. We should be able to get it fixed for the next 6.9.0 Beta.
Marty_M
Sep 18, 2017NETGEAR Employee Retired
Hello chainlinc,
I would like to verify the NAS and scanner is on the same local network? The 6.8.0 firmware did not made any changes on ftp access on the NAS. You have mentioned that if the resolution is set to low or medium it does work fine. There is a possibility that the NAS is lacking resources in scanning higher resolution files. Do you have ftp rate limit or ftp permission set on the shares that the scanner access. Can you provide the complete logs of the NAS, you may use file sharing website like wikisend and just PM the download link.
Marty_M
NETGEAR Community Team
