chainlinc
Sep 13, 2017Guide
6.8.0 breaks FTP
After upgrading to OS6 6.8.0, scans from my Lexmark MX410de multi-function scanner fail if the .pdf file being written to is not altered within about 3 seconds. This is a new failure that did not exi...
- Oct 03, 2017
We traced the cause of the issue, and have posted our findings to the ProFTPD bugzilla report. We should be able to get it fixed for the next 6.9.0 Beta.
chsu83
Sep 25, 2017Luminary
did you found a fix for that problem?
- chainlincSep 25, 2017Guide
chsu83 wrote:did you found a fix for that problem?
chsu83,
Sadly, I have not yet found a fix for the ReadyNAS.
- chsu83Sep 25, 2017Luminary
Puh.. can we contribute somewhere the logs or somewhat?
Unfortunately I don't see any correction in the Beta's.. how should they.. in the bugreport http://bugs.proftpd.org/show_bug.cgi?id=4319 is also no solution available.
If anybody (e.g. Netgear) has an account at proftpd, and I can contribute some files please inform me. (Perhaps I need to know how to start proftpd on readynas in verbose). Because there the os (where the failure is known) is only FreeBSD mentioned. Could be helpful to inform them about ReadyNAS Linux.
to specify things more precisely:
I'm using Readynas with 6.8.0
FTP works from Filezilla
But is broken from an OKI C5550 MFP
- Marty_MOct 02, 2017NETGEAR Employee Retired
Hello chainlinc,
There is a big possibility that the bug from the proftpd 1.3.6 might be causing the problem. It does appear that it is being look onto right now and there is chance that fix might be available soon.
Marty_M
NETGEAR Community Team
