chainlinc
Sep 13, 2017Guide
6.8.0 breaks FTP
After upgrading to OS6 6.8.0, scans from my Lexmark MX410de multi-function scanner fail if the .pdf file being written to is not altered within about 3 seconds. This is a new failure that did not exi...
- Oct 03, 2017
We traced the cause of the issue, and have posted our findings to the ProFTPD bugzilla report. We should be able to get it fixed for the next 6.9.0 Beta.
chsu83
Sep 25, 2017Luminary
did you found a fix for that problem?
Marty_M
Oct 02, 2017NETGEAR Employee Retired
Hello chainlinc,
There is a big possibility that the bug from the proftpd 1.3.6 might be causing the problem. It does appear that it is being look onto right now and there is chance that fix might be available soon.
Marty_M
NETGEAR Community Team
