Cheppetto
Oct 02, 2017Aspirant
6.8.1 on legacy RNS6U boot issues - upgraded usb package?
As i updated my backup NAS RNSU6 today it stuck in shutting down. After rebboting manually it is stuck on displaying "Readynas". I would love to try an USB firmware recovery but the last version av...
- Oct 02, 2017
You’ll need to rename the OS6 firmware .img file to RAIDiator-x86-something to get it to work with USB Boot Recovery for RAIDiator-x86 systems.
However if the problem is not with the firmware internal flash then USB Boot Recovery won’t help.
There are other possibilities e.g. a bad disk
Cliff_MI
Oct 02, 2017Guide
You can update the USB Boot file with the latest firmware by substituting the new image file for the old one.
Just download the current version of the that you want to use and swap out the firmware file.
Then just follow the directions on the USB Boot and it should work for you.
mdgm-ntgr
Oct 02, 2017NETGEAR Employee Retired
- CheppettoOct 02, 2017AspirantThanks a lot, will try with renaming.
I am aware that it might be a disk fault too, spin up sounded ok, and LEDs showed no error, but let's see and again thanks a lot. I thought that the package is signed with other keys that's why i asked.
So i will just rename the .bin to raidar*** and check if it works.- StephenBOct 03, 2017Guru - Experienced User
Cheppetto wrote:
So i will just rename the .bin to raidar*** and check if it works.Not raidar***
RAIDiator-x86-***
- CheppettoOct 03, 2017Aspirant
Thanks a lot for all the answers, i turned out to be a failed drive on slot 3, S.M.A.R.T. looks good for the disk, rebuild runs currently, let's see if it needs to be exchanged.
Sorry for not suspecting a drive fail, but it seems that on an Raidar unit this is not so easy to find out. In the end i was starting adding one disk after another to see which one prevents the unit from booting.
As said above thanks a lot for all the help, awesome as always
- Sep 05, 2015Retired_Member
