Cheppetto
Oct 02, 2017Aspirant
6.8.1 on legacy RNS6U boot issues - upgraded usb package?
As i updated my backup NAS RNSU6 today it stuck in shutting down. After rebboting manually it is stuck on displaying "Readynas". I would love to try an USB firmware recovery but the last version av...
- Oct 02, 2017
You’ll need to rename the OS6 firmware .img file to RAIDiator-x86-something to get it to work with USB Boot Recovery for RAIDiator-x86 systems.
However if the problem is not with the firmware internal flash then USB Boot Recovery won’t help.
There are other possibilities e.g. a bad disk
mdgm-ntgr
Oct 02, 2017NETGEAR Employee Retired
Cheppetto
Thanks a lot, will try with renaming.
I am aware that it might be a disk fault too, spin up sounded ok, and LEDs showed no error, but let's see and again thanks a lot. I thought that the package is signed with other keys that's why i asked.
So i will just rename the .bin to raidar*** and check if it works.
- Sep 05, 2015Retired_Member
