frengstad
Dec 17, 2013Follower
accessing disk 2 in a r102 (6.1.4)
accessing disk 2 in a r102 I've just bought a new r102 (my first NAS) came whit a 1TB toshiba disk and I installed a 3tb Seagate disk that I know is compatible whit the r102. I can see the disk i...
ReadySECURE
Dec 17, 2013Apprentice
You wouldn't have expansion of file system by just adding 1 disk. You basically go from JBOD (1 disk) to RAID 1 (2 disk). If you replace the original disk 1 with a 3TB disk, your volume should expand. You need 2 or more disks of equal size in order to have more space (redundancy).
