Tristyd
Oct 24, 2024Aspirant
Admin Page Login loop
Got a ReadyNAS 2100 V2 on OS 6. For some reason the last day or two, whenever I try and get into the Admin page on Safari on Mac, it says Your Admin Session Has expired, with some description why und...
Tristyd
Oct 28, 2024Aspirant
Good thinking that.
I just checked, and it hasn’t saved the password for the Netgear Admin Page.
Tristyd
Solved it!
Worked fine by using just the ip address of the NAS! If I add /admin/ to the end of it then it doesn’t work.
- PWS442Dec 01, 2024Guide
Sadly, I can only access from a Windows PC. My Macs loop on the Admin page using the IP address w/o the admin sub-page. I am running 6.10.10 on my ReadyNAS RN316. Restarted from RAIDar. Still the same.
- StephenBDec 01, 2024Guru - Experienced User
Are you trying https://nas-ip-address/admin? Or are you leaving the /admin out?
With or without continually loop on the logon. Safari is not happy with either of my new-ish Macs. Chrome on Mac is OK. Edge on W11 PC is OK. I have been on 6.10.10 for quite some time.
Thanks, Oh Great One!
