pstallwood
Feb 09, 2012Initiate
Administrator and password - Reset?
I haven't used my Readynas Duo for a while and have forgotten what username and password I set. I have tried to reset the password but neither my email address(es) nor my answer to the security que...
- Feb 10, 2012An OS Re-install will reset the admin password but leave data intact. See http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
See also http://www.readynas.com/kb/faq/boot/what_is_the_frontview_default_login_and_password_after_a_factory_default
If you really want to do a factory reset (wipes all data, settings, everything), I'd recommend doing that on 4.1.7 or later so that you get 4k sector partition alignment.
Dries1979
Feb 10, 2012Tutor
Hello all,
I am facing the same issue as described above..
* The https://NAS-IP/password_recovery will not work - it wil say it has send me an email, but the email never arrives
* I have reset my NAS (and pressed the "RESET" button in the back), but without any luck.
Still it will not reset to the standard username / password ("admin" / "netgear1").. :(
After 6 hours of trying I am getting a bit lost and confused what I am supposed to do now, help plz.. :wink:
