pstallwood
Feb 09, 2012Initiate
Administrator and password - Reset?
I haven't used my Readynas Duo for a while and have forgotten what username and password I set. I have tried to reset the password but neither my email address(es) nor my answer to the security que...
- Feb 10, 2012An OS Re-install will reset the admin password but leave data intact. See http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
See also http://www.readynas.com/kb/faq/boot/what_is_the_frontview_default_login_and_password_after_a_factory_default
If you really want to do a factory reset (wipes all data, settings, everything), I'd recommend doing that on 4.1.7 or later so that you get 4k sector partition alignment.
opti
Feb 12, 2012Aspirant
Hi. I have the NV+ V1 here. finally got it all working good last week, my htpc could see it and access it. Then I tried my WDTV live in the rumpus room. It could not see all the file for some reason. I then did a search through these forums and found a user with the same problem and he found a fix. I followed his steps. First thing I did, which is what got me stuck I beleive is I enabled DHCP on my NAS. Then frontpage froze. I closed the browser and then went into Raidar and noticed the IP address had changed. But now it won't accept the default username and password.
How do I get this to work without losing all the data I have spent hours putting on?
Thanks.
Thanks.
