makkistyle
Feb 13, 2023Tutor
Alarm in NetGear CP admin (relocated sector)
HI, Recently my NAS started showing me this issue alarm, is this something I can fix or I have to replace my HDD ?
AnishaA
Feb 13, 2023NETGEAR Employee Retired
Hello makkistyle
Welcome to the NETGEAR Community! 🙂
This error shows when the disks have an error count of more than 0 in the disk info logs. And the disk seems faulty.
You can download the logs and check the disk info.log
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Check for these four and if this count exceeds more than 0 then we suggest you replace that disk.
Have a lovely day,
Anisha A
Netgear Team
- makkistyleFeb 13, 2023Tutor
HI,
Thanks for your quick reply, as I'm not tech person and
can't read or understand the log file ..
but these numbers what I found :
- Health data
ATA Error Count: 3
Reallocated Sectors: 2768
Reallocation Events: 2768
Spin Retry Count: 0
Command Timeouts: 1
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 50
Start/Stop Count: 26
Power-On Hours: 43478
Power Cycle Count: 26
Load Cycle Count: 1829
- Health data
there is no way we can tell which one is fault ? as I have two disks
both raid 0
- StephenBFeb 14, 2023Guru - Experienced User
AnishaA wrote:
ATA Error Count: 0
Spin Retry Count: 0Check for these four and if this count exceeds more than 0 then we suggest you replace that disk.
makkistyle: FWIW, I think 0 is too low a threshold. Personally if I see steadily increasing counts for reallocated sectors, or if I see it exceed about 25 or so, I'll replace the disk. Another indicator is when I am experiencing poor performance, failed transfers, etc. There is no definitive answer on this, different folks have different thresholds on when a disk needs replacing.
One thing I would like to point out - Backup is the best way to keep your data safe. If you don't have a backup plan in place for your data, then you should set one up. With solid backups, disk errors are a nuisance and not a disaster. The forum community can help with setting up a good backup plan.
If you are using RAID-0, then you should back up all your data immediately. Everything on the volume will be lost if the disk fails. And everything will be lost when you replace the disk.
makkistyle wrote:
- Health data
Though people do have different criteria for replacement, this particular disk should definitely be replaced.
One thing I suggest is regularly running the disk test, from the volume settings wheel.
If you have two volumes, then run the test on both of them. This test will take a while, but there will be an entry on the log page when it completes. Note you can schedule these tests (using the volume schedule). I run one maintenance function per month (so the disk test runs every 4 months).
Once the test is complete, then you can look at the stats again.
As far as identifying the disk - this can sometimes be tricky. While some of the logs identify the first disk as 1, there are some spots where it is identifed as 0. Look in disk_info.log - the disk in the first bay is listed as "channel 0", the next bay is "channel 1". You can double-check by noting the serial number. Then power down the NAS, remove the disk, and check the serial number. (Put the disk back while the NAS is powered down).
- SandsharkFeb 15, 2023Sensei
You do it on the Performance screen. Just hover on the (hopefully green) dot next to the disk number:
Oh, and ATA errors alone can be cause by a problem with the NAS, not the drive. That's the case with the drive in my example, which was previously in a system that failed. But your drive is definitely on it's last legs.
- makkistyleFeb 16, 2023Tutor
Hi StephenB
I'm glad to see you here and have your input
as you suggested I did test disk
but it fail it seems one of the HDD is indeed needs to be replace
do you agree its better to replace both HDD rather than one of them
so I can be in safe side for future
here are some screenshot
- Health data
