tavantops's avatar
tavantops
Amber light on Power button
Hi,
We are observing amberlight on power button. Network/LAN lights are also not blinking but Power supply is working. We have restarted the NAS more then 2-3 times but no luck. We have a ticket openend  with Ready NAS but no one seems to be available on chat support or call suport. Its critical for us. Can anyone let us know if you have observed this issue before and how to resolve it  and how to reach out to teach support team
Thanks
Partha
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello tavantops,
    When the power LED is amber, it means the NAS is on standby mode. Try contacting support via CHAT, I checked the registration of your unit and it appears it is entitled to lifetime CHAT support.
    Welcome to the community!
    • tavantops's avatar
      tavantops
      Hi JennC,
      Thanks for your reply!! Do you know how can i start a chat session with NETGEAR Support. i couldn't able to find out and also to give an update after 3-4 attempts of restart the NAS started working and now its giving following error and the green light on PSU2 is blinking. I have replaced the power cable on PSU2 but still its blinking. Is it a good sign or bad.
      Wed Mar 8 2017 19:06:36 System: Power supply 2 in enclosure Internal is offline.
      Wed Mar 8 2017 19:06:20 System: Power supply 2 in enclosure Internal is offline.
      Wed Mar 8 2017 19:06:04 System: Power supply 2 in enclosure Internal is offline.
      Wed Mar 8 2017 19:03:17 System: Power supply 2 in enclosure Internal is offline.
      Wed Mar 8 2017 19:03:13 System: Power supply 1 in enclosure Internal is offline.
    • JennC's avatar
      JennC
      Hello tavantops,
      Try getting support site, you should be able to enter the SN of your NAS and it would load the available support for your product.
        tavantops
        Hi JennC,
        Thanks for your quick response!! i tried that option and it says "LIVE chat unavailable at the moment". Morning PST when i tried it was giving same message as well
        Thanks
        Partha
ProSupport for Business
