stevenestrada
Mar 18, 2018Aspirant
Another root volume full
Getting this after the the 6.9.3 update System volume root's usage is 81%. . System volume root's usage is 82%. . Someone suggested deleting apps. So I ldid. Deleted loganalyzer that never wor...
Mar 19, 2018Guru - Experienced User
stevenestrada wrote:
Someone ese said get rid if mysql. Doesn't the system need that?
The system doesn't use it, and it is not normally installed. I believe in your case it was needed for loganalyzer.
mdgm-ntgr
Mar 19, 2018NETGEAR Employee Retired
If you don’t need MySQL you can remove it using apt-get.
