stevenestrada
Mar 18, 2018Aspirant
Another root volume full
Getting this after the the 6.9.3 update System volume root's usage is 81%. . System volume root's usage is 82%. . Someone suggested deleting apps. So I ldid. Deleted loganalyzer that never wor...
Mar 19, 2018Guru - Experienced User
stevenestrada wrote:
Someone ese said get rid if mysql. Doesn't the system need that?
The system doesn't use it, and it is not normally installed. I believe in your case it was needed for loganalyzer.
stevenestrada
Mar 19, 2018Aspirant
Every update is another problem with this thing
That innodb trick reads like it'll take a big (650M for me) file and turn it into a bunch of little ones.
Im afraid to do that or shuffle stuff around with symlinks, etc figuring it explode into a bigger problem with the next update
The readynas OS don't need mysql?
I'll shut it off and see what happens
Is this how to get rid of it entirely:
# apt-get remove --purge 'mysql-.*'
- StephenBMar 19, 2018Guru - Experienced User
Correct.
