AndrewT1
May 21, 2013Aspirant
Anti-virus Not updating (6.0.6)
Hi , I have noticed that Anti-Virus signature files dose not update unless I reboot or disable /enable the service. Dose anyone know if this correct or just another software issue ? Thanks An...
May 24, 2013Guru - Experienced User
Then it should either check often enough that no one cares, or you should be able to set the schedule (agreeing with AndrewT's desire for more frequent updates).
