AndrewT1
May 21, 2013Aspirant
Anti-virus Not updating (6.0.6)
Hi , I have noticed that Anti-Virus signature files dose not update unless I reboot or disable /enable the service. Dose anyone know if this correct or just another software issue ? Thanks An...
Govnah
May 25, 2013Aspirant
chirpa wrote: Found it. Runs 10 minutes after boot, and once a week after that. # cat /lib/systemd/system/avdu.timer
[Unit]
Description=Anti-Virus Definition Update Timer
Requires=ctscand.service
[Timer]
OnBootSec=10m
OnUnitActiveSec=1w
Unit=avdu.service
You should be able to edit that file to be 1d instead of 1w. But firmware updates would overwrite the changes.
Thanks Chipra! You need to send Netgear a consulting bill as I have learned and addressed more issues from you than opening a ticket with Netgear.
