ZkiiFreak
Nov 24, 2014Aspirant
Anti-Virus Plus in IE11
Hi Hope someone can point this to the right subforum as I could not find a subforum for AV Plus (which in fact is developed by Netgear Inc) I have an RN314. Been running smoothly. I have issues w...
- Oct 26, 2015
At last I found the culprit. Better late than never.
I'll share the simple solution with you here :)
It turns out that IE identifies my NAS URL as an intranet zone (that's OK) but it uses compatibility view settings for this zone. Disable the compat view settings for intranet zone by de-selecting the checkbox "Display intranet sites in Compatibility View" in Compatibility View settings and viola!
mdgm-ntgr
Nov 24, 2014NETGEAR Employee Retired
When you fix things for one browser you can break another. IE is notorious for introducing changes that break functionality.
Hopefully this will be resolved in the next app update.
What version of ReadyNAS OS are you running?
Have you updated to 6.2.0 yet?
