PHolder's avatar
PHolder
Any plans for Samba fix for CVE-2017-7494 ?
I posted elsewhere about this, but CVE-2017-7494 NEEDs to be patched on any device still in operation, and I think that includes the older, technically out of support models that I have 6 of.
With Microsoft recommending disabling SMB 1.0 because of Wannacry and related security issues, it seems like an ideal time for Netgear to show some leadership and update SMB on all it's devices to address this security issue and to allow people to use older devcies with SMB 2 or 3 support.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      We've built firmware with the patch for CVE-2017-7494 for legacy models as well. Once they have undergone QA testing, I believe we plan to release those updates as well:
      RAIDiator-4.1.16
      RAIDiator-arm-5.3.13
      RAIDiator-x86-4.2.31
      As for SMB2 and SMB3, we're not updating to a newer samba series on the legacy models at this time so SMB2 support would remain experimental and remain disabled. The new firmware has the same samba version except with the patch so the netgearx at the end (where x is a number) would be incremented by one to reflect the change.
      • ciarpame's avatar
        ciarpame
        Tutor
        Do you have an ETA?
        Does it mean that on my Readynas NV+v2 there is a buried disabled SMB2 I can enable by myself in some way via Putty? Can you point me to some helpful resource to do it? Side effects? Thank you
    • sfriis's avatar
      sfriis
      Tutor
      I just upgraded to 6.7.3, but appearantly smbd is still v 4.4.9:
      Welcome to ReadyNASOS 6.7.3
      Last login: Fri May 26 12:58:49 2017 from xxxxx
      root@xxxxxx:~# smbd --version
      Version 4.4.9
      root@xxxxxx:~#
      Am I missing something??
      • ctechs's avatar
        ctechs
        Apprentice
        Since this was a point release, the netgear team likely backported the fix instead of upgrading samba to the latest and greatest, to avoid breaking things.
ProSupport for Business
