dhl
Oct 07, 2017Luminary
Any way to turn off power alerts?
Now that all our backup jobs are working properly, our 104 is on a nightly power timer. Is there any way to turn off the daily "The system is shutting down." emails I'm getting now? The check box...
- Oct 07, 2017
Unfortunately you'll need to wait for Netgear to improve the alert options.
Oct 07, 2017Guru - Experienced User
- dhlOct 07, 2017Luminary
StephenB wrote:Unfortunately you'll need to wait for Netgear to improve the alert options.
Thanks StephenB, I guess untill then I'll set a filter in my email client.
- AmidalaOct 15, 2017NETGEAR Employee Retired
In the next release version, user can select or unselect "Power" option in Alerts settings.
