iangls
Mar 31, 2014Aspirant
APC Powerchute and ReadyNAS Duo
Hi All, Ive done some searching and havent really found anything that seemed to help. I have a ReadyNAS duo working faithfully away and recently discovered the old cheapie UPS had deceased. I ...
Mar 31, 2014Guru - Experienced User
All you should have to do is connect the USB port of the UPS to the Duo. You don't actually need powerchute at all.
