iangls
Mar 31, 2014Aspirant
APC Powerchute and ReadyNAS Duo
Hi All, Ive done some searching and havent really found anything that seemed to help. I have a ReadyNAS duo working faithfully away and recently discovered the old cheapie UPS had deceased. I ...
iangls
StephenB wrote: All you should have to do is connect the USB port of the UPS to the Duo. You don't actually need powerchute at all.
OH ok - thank you - how do i know what IP address to put in the field in the Duo software or does it do that by itself?!
