x219c
Nov 26, 2014Luminary
Apps not appearing in frontview
Okay... Factory resetting is getting really really old. Got my RN516 all factory reset for the third time, and got most of my data back on it and I went to the apps page to make sure I corrected anoth...
mdgm-ntgr
Nov 26, 2014NETGEAR Employee Retired
When you delete your volume, the apps directory on it is deleted and this means the Available Apps tab won't work.
After you have created the volume you want, if you do an OS Re-install or install 6.2.0 over the top of itself is the Available Apps page fixed again?
Have you tried clearing your web browser cache (e.g. Temporary Internet Files in IE), closing your web browser then reopening the Dashboard?
