x219c
Nov 26, 2014Luminary
Apps not appearing in frontview
Okay... Factory resetting is getting really really old. Got my RN516 all factory reset for the third time, and got most of my data back on it and I went to the apps page to make sure I corrected anoth...
x219c
man, man, man... I think I was on the https port the last time around. What's strange is I've been using the https frontview all along (i just checked my bookmark) Up until switching to 6.2. (admittedly, I made the jump to RAID6 at the same time) I had absolutely no problems... As far as the app changing the symlinks, that doesn't sound bad, but I didn't install a single thing before checking that area... At the moment, it's sounding like mdgm's idea might be it. The only thing I do after a factory reset is destroy the volume and go raid6. Nothing installed or anything. My game plan for the moment is to get finished rebuilding the volume and reinstall os6.2. Once I get that finished, it'll rule out the apps folder as the culprit. dnspevl, I can see the code, but wouldn't know how to do much with it. It could be the problem, but I really wouldn't know. I guess I wasn't expecting to have to get into the command line to get RAID6 working. I'll see where we're at in a little bit.
