x219c
Nov 26, 2014Luminary
Apps not appearing in frontview
Okay... Factory resetting is getting really really old. Got my RN516 all factory reset for the third time, and got most of my data back on it and I went to the apps page to make sure I corrected anoth...
dsnpevl
Nov 27, 2014Virtuoso
x219c wrote: dnspevl, I can see the code, but wouldn't know how to do much with it. It could be the problem, but I really wouldn't know. I guess I wasn't expecting to have to get into the command line to get RAID6 working. I'll see where we're at in a little bit.
No problem. I just noticed the same symptoms that I encountered in the image you included and thought I'd share my experience. But it seems the symptoms I encountered had a very different root cause than yours.
mdgm wrote: SSH is not necessary for end users. Some advanced users like to use it and we include it for them, but we certainly don't expect our users to SSH in to look at things.
I agree and this was my initial plan to begin with when I first bought the NAS. Just use the web admin interface and leave the OS and SSH command line terminals alone. Especially if NetGear might void the warrenty if you change the system and doesn't support you in using the command line via SSH. But when something basic like SSI is not enabled by default and no one could tell me what to change exactly to turn it on, I was left with little other choice than to figure it out myself. Invested a lot of time to figure out how to configure the Apache webserver, that I had rather spent on using the apps on the system. But in the end it is time well spent, because I now have more control over the configuration of the webserver on RN516.
