claytonb
Nov 01, 2011Aspirant
Backing up data between 2 NAS units?
Hi, I am looking at getting 2 x ReadyNAS RND2000-100AUS units to use at seprate locations, my question is, is it possible to back up data from 1 NAS unit to another without a computer?
mdgm-ntgr
Nov 01, 2011NETGEAR Employee Retired
Would not recommend you use the Duo for this.
I would recommend two Pro 2 (RNDP2000) units using ReadyNAS Replicate (http://www.readynas.com/replicate) or Rsync over SSH.
Whilst you could use the Duo for Rsync this is not secure. So you'd either have to setup your VPN or use a community add-on to do Rsync over SSH (performance may be unbearably slow).
