michelefaccini
Dec 26, 2013Aspirant
BACKUP FILES SYSTEM
Hi all, after an awful mistake I partially deleted the etc folder from the putty shell. Because an OS re-install was unsuccessful, I had to do a Factory reset. At the following link https://wiki.arch...
michelefaccini
Dec 28, 2013Aspirant
Thanks Stephen for your exhaustive answer.
I've just installed the Rsnapshot super-poussin's addon. Initially I would like to use it to locally backup important file like php.ini, httpd.conf, to dump automatically my databases,...so in case I would have updated files that can be restored. If I managed to do that I will try for a remote backup on my Desktop PC ( this involve permissions to be set on Windows 7 folder).
I did a 'search' on the forum 'addons' section and I wonder to find no post about that addon....
