yarramreddy
Sep 24, 2015Aspirant
backup issue
Hi, Currently i am using Ready NAS 104 with 5.44TB. Few days back i have deleted on file of size 750 GB from storage. I have some more free space. Total it is showing 940Gb free space. if i start ...
yarramreddy
Sep 25, 2015Aspirant
Dear Sir,
Please see the screen shots.....i am getting the same error even i reshedule...
kindly help me out
Sep 25, 2015Guru - Experienced User
Did you do what I suggested? That is, go into the NAS web ui, go to system->settings, and create a maintenance task to run a balance job?
Unfortunately you need to schedule it, there is no way to just start it.
- mdgm-ntgrSep 25, 2015NETGEAR Employee Retired
StephenB wrote:
Unfortunately you need to schedule it, there is no way to just start it.Since 6.2.3 volume balances have been able to be run manually via the UI, and since 6.2.0 you've been able to schedule them.
yarramreddy wrote:
We have importent data of 4tb......if i do any changes, does they affect existing data............
kindly help us......
You should backup your data as StephenB suggested. If a balance isn't working on the firmware you are currently running if you don't use ReadyCLOUD you could update to 6.4.0 beta and try running a balance again.
