RN104Owner
Feb 05, 2015Aspirant
Backup not complete again
I purchased my RN104 this week. It is a very nice NAS box for its price. It came with OS6.2 out of the box. I updated it to 6.22 then set it up with 3 - 4TB drives in raid5 and let it run over night building the array.
Yesterday morning it was going to take 30+ hours to finish building the array. So I started backing up the home media server, a Javelin S4 that has 3 - 4TB drives in raid5 with ~4.5TB of data. It has about 600 DVD iso files and each has 2 small files for a total of 1800+ files. I setup a backup job on the RN104 and got it running. I was pleasantly surprised to see the backup moving at 1TB/8hrs. I used NFS to setup the backup job since both boxes are Linux.
This morning when I checked, the backup was complete! Well not really. The RN104 showed about 1.2TB copied. I started the backup job again and it promptly ran through its sequence and pronounced the second backup complete without doing anything. So I removed the 1200+ small files and started the backup job again. It is now, again copying the iso files. I'll add back the smaller files later.
While the backup job is running I turned to google and found others having the same issue. OS6.2/6.22 set the NFS thread count to 8. I changed it to one and the web interface became slow to respond. Next I set the NFS thread count at 2 and the web interface seems "normal" again. For a dedicated home media server, what is a good number for NFS thread count?
- krgoodwinApprenticeThat is exactly what I have, the folder is shared (everybody full control) and when I put in just the share name the Test Connection fails (invalid username and/or password) and the backup job fails (unable to mount source). The full windows path is c:\users\myaccount\sourcefolder or network share path \\HP-H9-1215T\sourcefolder. When I use Users\myaccount\sourcefolder the Test Connection passes and the backup job executes but no output. I find it works the same if I omit the sourcefolder from the path (Users\myaccount) so obviously it isn't finding the source folder but yet the backup job executes without a whimper. I'm lost as so is Netgear so far. They asked for my logs today but since the job executes, not sure what one is going to see in a successful execution. Ken Goodwin, Houston
- StephenBGuru - Experienced UserYou should be using "sourcefolder" as the path. Try using your windows username and password on the backup job.
- krgoodwinApprenticeI agree with your suggested procedure but therein lies the problem, I don't use an administrator password. When I follow your (and mine) steps, I get a Username and/or password failure on the Test Connection. When I execute the backup - failure to mount source error. I was able to get around the Test Connection failure by using a full path name (Users\Myaccount\SourceFolder) but it appears as if the backup job doesn't find nor use a source yet executes without a whimper. According to the experts if the Control Panel --> Network and Sharing Center --> Advanced Sharing Settings is set to Off for Password Protected Sharing one should be able to do this without a password. I am of the opinion that Netgear has a bug in this area. I have no problems creating and executing a backup job from the ReadyCLOUD app interface but it won't work from the Admin page interface (the word FrontView no longer exists in the Netgear vernacular). I will try creating the same backup job on my tablet that does have an Administrator password but after spending 20 hours trying to get this to work, I need a break.
- StephenBGuru - Experienced UserYou are saying that "myaccount" on the PC has no password? It does have a username, all windows accounts do. It might also help to make sure that the Windows workgroup on the NAS matches the PC.
Also, to enable full access to data in the share, you need to ensure that the file permissions in Windows are also set properly. Network access is only part of it. Windows always applies the most restrictive permissions. So both need to be set to full everyone access. - krgoodwinApprenticeYou are saying that "myaccount" on the PC has no password? It does have a username, all windows accounts do. It might also help to make sure that the Windows workgroup on the NAS matches the PC.
Well you will have to tell me where it is since I've never created one nor have never been asked for it in over four years with this computer (except for maybe now). NETPLWIZ will take me to the User Accounts where the Reset Password for the administrator account (myname) is greyed out indicating to me that no password exists. The Credential Manager, as expected, shows the existence of passwords for all my other computers but not the desktop in question. I have attempted to use numerous usernames and passwords in the ReadyNAS backup job creation (I do have a self-administrated high security password scheme that I would have used if I ever created one for this computer) but never this provided a solution. If the ReadyCLOUD app can do a backup never asking for a password, it begs the question why the Admin interface can't do one. Tell me where my password might exist. I have an encrypted file that is over ten pages in length where I have recorded every password I have ever created in the last 20 years. I kind of remember that when one installs Windows, the trick was to do a CR when it asked to establish an Administrator password.
I've checked the Workgroups and they match as expected. (Windows default WORKGROUP)
I've been thru the advanced sharing folder steps for the Sourcefolder. My source of what seems to work is the YouTube video by Mammouth Jerk (love that name) entitled How to set a Backup with a Netgear ReadyNAS step by step. The tutorial is using a slightly older version of the ReadyNAS OS but generally the 30 minute video looks like the most viable knowledge source. The Netgear documentation (ReadyNAS OS 6.2 Software Manual is out of date). It indicates that one should be able to use the pull-down menu to select the source but it is greyed out when I am creating the backup job. The destination pull-down menu selection works but I would speculate that maybe because the source is remote, the source selection can't be accessed by the backup job creation process? (Really doesn't make much sense does it?)
Again my next step will be to try to create a backup job on my Windows 8 tablet which does have an Administrator password and see if I can get the backup job creation to execute in that environment. And maybe for argument purposes, I will then try it on my Windows 7 laptop which also has an administrator password. But since I've lost a fast bootup, maybe I should raise the flag and create an Administrator password and see if that solves the problem. One can use the User Accounts settings to avoid having to type a password during the bootup but after wasting two days of my life with this problem, I've gotten stubborn. - StephenBGuru - Experienced UserWhat version of Windows? Normally you are required to create a user name as part of the windows setup when you first turn on the PC. Usually there is a password as well - though there are ways to turn that off.
The windows username is what you called "myaccount".
You can confirm this by clicking control-alt-delete on the windows system, and (if needed) select "start task manager". Then click on the users tab on the far right. That will show you your windows user name.
Use that name (not administrator) as credential for the Windows share in the NAS backup job. If there is no password, then leave that entry blank.
