peter2011
Aug 23, 2014Aspirant
Backup not working and test connection made home page blank
I have been happily backing up one Pro 6 to another for well over a year, using standard backup of C of ReadyNas 1 to backup share of ReadyNas 2. This essentially created a mirror image. For some ...
Aug 23, 2014Guru - Experienced User
A filing OS partition can cause loss of frontview, as can a very heavy CPU load. Corruption in the OS partition is another possibility.
I suggest contacting support (the pro warranty is 5 years, so if you are the original purchaser you likely are still entitled to support). Use the email method at support.netgear.com.
