Annamarie
Jan 16, 2016Aspirant
Backup Routine renders FrontView and Data on NAS inaccessible.
I have recentely purchased a replacement Chassis for a client, installed the HDs from the failed drive (yes, I checked to be sure they were compatible) and am now attempting to configure the 'disaste...
Jan 16, 2016Guru - Experienced User
What NAS and what firmware is it running?
Annamarie
Jan 17, 2016Aspirant
ReadyNAS 104
Version 6.4.1 - Firmware - update check reports no update needed.
Backup failed.
The following was on the status window: __percup_counter_add#20
USB device is not longer reportin under Volumes and cannot be accessed via start + run [nameofdevice]
Rebooted and device is now working with respect to accessing data and Frontview.
