Annamarie
Jan 16, 2016Aspirant
Backup Routine renders FrontView and Data on NAS inaccessible.
I have recentely purchased a replacement Chassis for a client, installed the HDs from the failed drive (yes, I checked to be sure they were compatible) and am now attempting to configure the 'disaste...
Jan 16, 2016Guru - Experienced User
What NAS and what firmware is it running?
Annamarie
Jan 17, 2016Aspirant
ReadyNAS 104
Version 6.4.1 - Firmware - update check reports no update needed.
Backup failed.
The following was on the status window: __percup_counter_add#20
USB device is not longer reportin under Volumes and cannot be accessed via start + run [nameofdevice]
Rebooted and device is now working with respect to accessing data and Frontview.
- mdgm-ntgrJan 17, 2016NETGEAR Employee Retired
Which services and apps are you running?
What brand and model is the USB disk?
- AnnamarieJan 17, 2016Aspirant
No Apps running
Services as follows: SMB, AFP, ReadyDLNA, UPnp, HTTP, HTTPS
External USB 3.0 Drive: Fantom GFP3000EU3
The Backup drive was unplugged and reconnected and can now be seen in the Volume Listing. The backup did begin but did not complete. Some of the data was copied.
- BrianL2Jan 17, 2016NETGEAR Employee Retired
Hi Annamarie,
Can you extract the backup log file found in the UI? If you will connect your USB hard drive in your PC, is it working properly? You may also want to run disk error checking tool to scan for errors.
Kind regards,
BrianL
NETGEAR Community Team
