cboudet
Aug 22, 2016Aspirant
beginner question Easiest way to create automatic backups to readynas from windows PC
I just installed a readynas duo v1 to my router and would like to set up an automatic backup (file copy, uncompressed) from my windows pc, and I am new at using nas and raid. I can map the nas as a ...
- Aug 28, 2016
Thanks to those who tried to help me.
I decided to buy acronis and use it to back up the data to the readynas.
Aug 22, 2016Guru - Experienced User
cboudet wrote:
I have not been able to reset the admin password. I need help there also.
Do you get a login prompt when you go to https://nasipaddress/admin (using the real NAS ip address)?
What version of windows?
- cboudetAug 22, 2016Aspirant
I have different operating systems in the network, xp professional, seven professional and 10
Thanks,
I found the admin information. I was looking at the version 2 manual instead of the version one because it is labeled v2 at the bottom but it is actually v1.
I still need help setting up to back up to it.
Thanks
- StephenBAug 23, 2016Guru - Experienced User
cboudet wrote:
I still need help setting up to back up to it.The best way is to get a backup tool that runs on the PCs, and which supports Windows Network Shares as a backup target.
I use Acronis TrueImage that way myself. Some posters like FreeFileSync; I haven't tried it myself.
- BrianL2Aug 23, 2016NETGEAR Employee Retired
Hi cboudet,
Welcome to the community!
These articles will show you how to you can create and run a backup job between your PC, and your ReadyNAS.
Backing up data on my ReadyNAS
Backing up data between ReadyNAS and Windows 7, 8 or 10 (SMB) share
With regard to your other question about resetting the admin password, are you having problems accessing the Frontview or admin page?
Kind regards,
BrianL
NETGEAR Community Team - cboudetAug 23, 2016Aspirant
Thanks,
