cboudet
Aug 22, 2016Aspirant
beginner question Easiest way to create automatic backups to readynas from windows PC
I just installed a readynas duo v1 to my router and would like to set up an automatic backup (file copy, uncompressed) from my windows pc, and I am new at using nas and raid. I can map the nas as a ...
- Aug 28, 2016
Thanks to those who tried to help me.
I decided to buy acronis and use it to back up the data to the readynas.
cboudet
I have different operating systems in the network, xp professional, seven professional and 10
Thanks,
I found the admin information. I was looking at the version 2 manual instead of the version one because it is labeled v2 at the bottom but it is actually v1.
I still need help setting up to back up to it.
Thanks
Aug 23, 2016Guru - Experienced User
The best way is to get a backup tool that runs on the PCs, and which supports Windows Network Shares as a backup target.
I use Acronis TrueImage that way myself. Some posters like FreeFileSync; I haven't tried it myself.
