Linez
May 13, 2012Aspirant
Blu Ray LG BD670 crashes when connecting to ReadyNas Duo V2
Hi, My Blu Ray player LG BD670 can't connect to my Readynas Duo V2. My systems setup is: - RAIDiator-arm-5.3.4 - ReadyDLNA is re-activated in the Dashboard(Was turned off for some time, as I d...
Linez
May 21, 2012Aspirant
Skywalker,
Thanks. Can you advise how to disable the LMS and turn it back on ?
Do I need to forward this issue to Logitech, or will this happen through the ReadyNAS-Logitech working relationship.
Thx
Thx
