Linez
May 13, 2012Aspirant
Blu Ray LG BD670 crashes when connecting to ReadyNas Duo V2
Hi, My Blu Ray player LG BD670 can't connect to my Readynas Duo V2. My systems setup is: - RAIDiator-arm-5.3.4 - ReadyDLNA is re-activated in the Dashboard(Was turned off for some time, as I d...
Skywalker
May 21, 2012NETGEAR Expert
You can disable just the UPnP/DLNA plugin by going to the LMS setup page:
http://[nas_address]:9000/settings/index.html
Then go under the Plugins tab, uncheck the box next to UPnP/DLNA Media Interface, and click Apply. When prompted, choose Restart Now.
I'll try and get this sorted between Logitech and LGE.
