rjwerth1
Jan 31, 2015Aspirant
Bonded Network adaptors #24629694
Hold on to your hats, this one is a lulu. I have a call into tech support, but I think this needs to be seen by all. The trouble started when I changed the name of my 516 after I had it configured...
Feb 02, 2015Guru - Experienced User
LACP generally won't improve performance for a single connection. It's designed for trunking, so clients using unbonded connections will still see packets in order with no drops. That limits performance gains when both clients are bonded connections.
Layer 3+4 hashing might help some, but only if layer 4 is using multiple ports.
