Tennessee_Slim
Dec 24, 2013Aspirant
Both NVs drew the same IP address (DCHP)
I have an NV and an NV+, both on the v4.1.10 firmware. I changed IP ranges on my DHCP server and rebooted the NASs to let them pick up the change. They both are on reserved IPs but when they booted ...
Dec 25, 2013Guru - Experienced User
I'm glad they're up again.
You wouldn't have needed a crossover cable btw. The NAS autosenses, so a straight cable would have worked fine.
