joki
Oct 08, 2015Tutor
btrfs-cleaner frequently stuck at 100% CPU after 6.4.0 upgrade
Since I upgraded my RN102 to 6.4.0 last night I frequently have trouble reaching the admin interface, and my laptop has reported not being able to reach Time Machine. When I login by ssh and use ...
- Oct 21, 2015
It seems like I found a way to get rid of the hanging btrfs-cleaner: After switching off quota
btrfs quota disable /data
btrfs-cleaner did never show up again (in top).
(After booting I usualy had about a minute to issue the command before btrfs-cleaner did spawn and prevented the command to respond.)
I did not intentionally enable quota - i guess it was enabled by default.
Good luck,
HansW
PS: Maybe the problem is known by Netgear - in their "FAQs on recently released firmware 6.4.0" (see link on top of page) they talk about "... this is likely due to the ReadyNAS performing a quota check".
Some websites also describe problems with quota and btrfs (Rockstor forum), other sites cite the quota support in btrfs as experimental (but these might be out of date).
I did not extensive testing after diabling quota that way - I'm happy that I can acces my files again ...
joki
Nov 03, 2015Tutor
HansWeihnacht wrote:It seems like I found a way to get rid of the hanging btrfs-cleaner: After switching off quota
btrfs quota disable /databtrfs-cleaner did never show up again (in top).
Hi Hans,
like you, I haven't enabled quota myself and they're not used in any of my shares.
I would've tried the "quota disable" command if it had been obvious whether it destroys all of the qgroups on the volume (visible using "qgroup show /data"). Is this documented anywhere for btrfs?
It's also not clear how to re-enable quota if it requires re-creating all the qgroups as described on the wiki. Is it documented anywhere how ReadyNAS OS requires qgroups to be set up?
In the end, by the time I got access to my NAS 6.4.1-T21 beta was out, so I installed it and haven't had problems since (after 10h of uptime, btrfs-cleaner is still below 7s of CPU time). So I'll consider this fixed if the beta ever turns into a release.
Cheers,
joki
cwoodfield
Nov 25, 2015Aspirant
I see a similar issue, but not matching the descriptions exactly. In my case, top doesn't show btrfs-cleaner using 100% CPU, but if I install iotop, I see the process eating all of the available disk IO, meaning that most of the CPU is spent in iowait. This causes any other disk-bound process to run extremely slowly; I see similar usability symptoms as others (slow FrontView response, failed NAS mounting, file reads, etc).
This has been persistent under 6.4.0 and the latest 6.4.1 RC3 (running RC3 and observing this as I type):
Total DISK READ: 759.25 K/s | Total DISK WRITE: 0.00 B/s TID PRIO USER DISK READ DISK WRITE SWAPIN IO> COMMAND 1938 be/4 root 381.48 K/s 503.70 K/s 0.00 % 97.83 % [btrfs-cleaner] 1939 be/4 root 374.07 K/s 500.00 K/s 0.00 % 96.80 % [btrfs-transacti]
