joki
Oct 08, 2015Tutor
btrfs-cleaner frequently stuck at 100% CPU after 6.4.0 upgrade
Since I upgraded my RN102 to 6.4.0 last night I frequently have trouble reaching the admin interface, and my laptop has reported not being able to reach Time Machine. When I login by ssh and use ...
- Oct 21, 2015
It seems like I found a way to get rid of the hanging btrfs-cleaner: After switching off quota
btrfs quota disable /data
btrfs-cleaner did never show up again (in top).
(After booting I usualy had about a minute to issue the command before btrfs-cleaner did spawn and prevented the command to respond.)
I did not intentionally enable quota - i guess it was enabled by default.
Good luck,
HansW
PS: Maybe the problem is known by Netgear - in their "FAQs on recently released firmware 6.4.0" (see link on top of page) they talk about "... this is likely due to the ReadyNAS performing a quota check".
Some websites also describe problems with quota and btrfs (Rockstor forum), other sites cite the quota support in btrfs as experimental (but these might be out of date).
I did not extensive testing after diabling quota that way - I'm happy that I can acces my files again ...
spotcatbug
Oct 12, 2015Apprentice
I'm in the same boat. Just want to chime-in, lest anybody think this is a rare problem with 6.4.0.
Just now, I've had a browser window open, trying to connect to the admin pages (all I've seen for the past 90 minutes is the splash screen, after authenticating). Simultaneously, I've had a ssh terminal window open, running top on the NAS. At the exact moment that the btrfs-cleaner process went to 0% CPU, the admin page finally popped-up.
