joki
Oct 08, 2015Tutor
btrfs-cleaner frequently stuck at 100% CPU after 6.4.0 upgrade
Since I upgraded my RN102 to 6.4.0 last night I frequently have trouble reaching the admin interface, and my laptop has reported not being able to reach Time Machine. When I login by ssh and use ...
- Oct 21, 2015
It seems like I found a way to get rid of the hanging btrfs-cleaner: After switching off quota
btrfs quota disable /data
btrfs-cleaner did never show up again (in top).
(After booting I usualy had about a minute to issue the command before btrfs-cleaner did spawn and prevented the command to respond.)
I did not intentionally enable quota - i guess it was enabled by default.
Good luck,
HansW
PS: Maybe the problem is known by Netgear - in their "FAQs on recently released firmware 6.4.0" (see link on top of page) they talk about "... this is likely due to the ReadyNAS performing a quota check".
Some websites also describe problems with quota and btrfs (Rockstor forum), other sites cite the quota support in btrfs as experimental (but these might be out of date).
I did not extensive testing after diabling quota that way - I'm happy that I can acces my files again ...
joki
Oct 19, 2015Tutor
Just wanted to post an update to emphasise that this problem is in fact still occurring. Many times a day my NAS becomes unresponsive due to extremely high CPU usage of btrfs-cleaner.
As shown by top, btrfs-cleaner has been running for 2669 minutes (nearly 2 entire days) in a total uptime of 11 days, while readynasd has only used 75 minutes of CPU time:
top - 17:04:15 up 11 days, 18:01, 1 user, load average: 0.67, 0.65, 1.02
Tasks: 140 total, 1 running, 139 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.7 us, 4.6 sy, 0.0 ni, 51.1 id, 42.6 wa, 0.0 hi, 1.0 si, 0.0 st
KiB Mem: 508804 total, 483508 used, 25296 free, 3424 buffers
KiB Swap: 523708 total, 16 used, 523692 free, 369660 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2583 root 30 10 0 0 0 S 0.0 0.0 2669:52 btrfs-cleaner
2905 root 19 -1 186m 29m 8640 S 0.3 6.0 75:54.44 readynasd
2624 messageb 20 0 4020 1356 900 S 0.0 0.3 19:35.37 dbus-daemon
404 root 20 0 0 0 0 S 0.3 0.0 6:48.03 kswapd0
7 root 20 0 0 0 0 S 0.0 0.0 5:51.99 rcu_sched
This problem did not exist before upgrading to 6.4.0 from 6.2.5. Since the upgrade, there have been no unusual activities such as deleting large amounts of files or data or removing snapshots.
There has been no response from Netgear so far regarding how to enable logging to find out why btrfs-cleaner is taking so much time or which features to disable in order to work around the problem.
jameswalmsley1
Oct 20, 2015Aspirant
I have noticed this, it happens if I manually delete a very large snapshot.
James
