janpeter1
Oct 17, 2016Luminary
Camera import function OS 6.5 on
Hi, I have used ReadyNAS 314 for about a year now and works fine. The last few days I have started to use the Backup/Import function where you can specify where photos from a camera should ...
ajahearn
Mar 19, 2017Aspirant
I have a similar issue but I am also finding that the device only copies files with a .jpg extension whereas most of my photos are stored in the Nikon RAW (NEF) format. It would be very useful if I could connect up the camera, have it look for any new files, and back those up in the same organization as the memory card.
FramerV
Mar 27, 2017NETGEAR Employee Retired
Hi janpeter1,
This could be a good addition to our Idea Exchange for ReadyNAS.
If in case you have not posted this yet, please do so.
I will also be inquiring about your case as well.
