mrkclw
Sep 26, 2015Aspirant
Can my Neatgear ReadyNas 10200 connect to router by using Wifi dongle ONLY?
Hi all, I just brought a ReadyNas 102 recently and everything runs smoothly. One thing I really want to do is to connect to the my Netgear router (N300) by using my Wifi dongle as I want to put my NA...
- Oct 15, 2015
I think I'd try to find another way to shield the NAS from the cat. Maybe get a small pet wire cage, and put the NAS inside? Likely the cheapest solution.
As far as bridge mode - I think you are perhaps confused.
Your router is single band, so if you want to use it for wifi you would leave it alone. You can add an wifi extender (or purchase a new router that supports bridge mode). Any of the extenders here should work: http://www.netgear.com/home/products/networking/wifi-range-extenders/ With your current router the WN3000RP is enough (your router WiFi can't handle anything more capable).
A much more expensive (but more capable) WiFi solution would be to get a Nighthawk R7000 router and a EX7000 extender. You'd put the Nighthawk behind your current router (connecting everything to the R7000), and turn your current WiFi off. Then use the extender in the bedroom. You'd upgrade your WiFi speeds overall, as well as being able the connect up the NAS. FWIW, you can use a second router instead of the EX7000 extender, if you set it up in bridge mode.
Or use powerline (http://www.netgear.com/home/products/networking/powerline/) A pair of PL1200s would do nicely.
mrkclw
Oct 14, 2015Aspirant
Thanks for your reply.
The main reason why I want to put NAS in my bedroom is I don't want my pets to touch it as sometimes they may play with my NAS.
I've been trying this for a few days but I still don't know how to set my devices up as I couldn't find any anything is related to what you mentioned in your previous post. The only thing I can find is the "repeater" mode. Here is the user manual that I found on the Internet. (http://www.downloads.netgear.com/files/GDC/DGN2200V3/DGN2200v3_UM_07Oct2013.pdf)
This is the router that I'm having for now.
Oct 15, 2015Guru - Experienced User
