mgiammarco
Oct 14, 2014Aspirant
Can you do a crash test for me?
Hello, I am getting crazy, I have a readynas 102 with os 6.1.9. I create a nfs share. I mount the share in a client Then I do a "bonnie++ -u youruser -s 100000" It is a simple perftest. My read...
mdgm-ntgr
Dec 02, 2014NETGEAR Employee Retired
1. This test with a new share with bitrot protection and snapshots disabled will help to isolate the cause of your problem. You could also see if enabling async on the share helps: http://kb.netgear.com/app/answers/detail/a_id/14765/~/how-do-disable-nfs-sync-mode-in-readynas-os-6,-to-improve-nfs-performance
2) NFS is tested, but you may be putting too much load on the system. What is the NFS thread count?
Are you able to send me your logs (see the Sending Logs link in my sig)? Perhaps your logs will give me some clues as to what is going on on your system.
