mgiammarco
Oct 14, 2014Aspirant
Can you do a crash test for me?
Hello, I am getting crazy, I have a readynas 102 with os 6.1.9. I create a nfs share. I mount the share in a client Then I do a "bonnie++ -u youruser -s 100000" It is a simple perftest. My read...
mgiammarco
Dec 04, 2014Aspirant
HI have done several tests and I suppose I have isolated the problem:
1) create an nfs share with snapshots, bitrot and compression (just to be sure): crash always
2) create an nfs share with nothing and THEN ADD snapshots then bitrot then compression (the order may change) : no crash bonnie benchmark completed
Please note that for "crash" I do not mean "is very slow" but I mean: no response from gui or telnet or power button so I need to detach power cord.
I will do it now and then I send logs to you but then you must not reply "software problems are not covered by warranty".
