mgf
Oct 25, 2015Aspirant
Can't access web interface since firmware 6.4
ReadyNas 102 Firmware 6.4 updated through web interface. When I turn on the device the power light has a slow flash and this never stops. After this I can no longer access the web interface ...
- Oct 26, 2015
Wasn't able to see NAS using RAIDar either.
However, I managed to get it resolved by carrying out an OS reinstall (http://kb.netgear.com/app/answers/detail/a_id/22892)
After that everything is working fine.
mdgm-ntgr
Oct 25, 2015NETGEAR Employee Retired
Can you see the NAS in RAIDar?
mgf
Oct 26, 2015Aspirant
- RowleyBirkinQCOct 26, 2015Aspirant
Hi mgf,
I have the same issue but the link to your solution is dead. Are you able to point me in the right direction?
Thanks in advance for any help- StephenBOct 26, 2015Guru - Experienced User
Have you gone through these steps? http://kb.netgear.com/app/answers/detail/a_id/29961?utm_source=community&utm_medium=announcement&utm_campaign=readynasfirmware
- redpolaNov 02, 2015Aspirant
That link is broken.
- StephenBNov 02, 2015Guru - Experienced User
It works when I click on it.
Or look at the "important updates" box on the top right (when you go into the ReadyNAS forum).
Ok, so then this forum doesn't work. :)
I hit "reply" to message #3 and that link was the broken one, not the link you posted.
Why do all messages have a "reply" button when all replies go at the bottom of the thread and don't explicitly refer to the message whose "reply" button was pressed?
- Kova7653Nov 03, 2015Aspirant
The link for the fix is here : http://kb.netgear.com/app/answers/detail/a_id/22892
The original poster accidently included a ) at the end rendering it a broken link...
mgf wrote:Wasn't able to see NAS using RAIDar either.
