ovrdrvn
Aug 15, 2016Aspirant
Can't Mount SMB/CIFS Shares in OS X Sierra Public Beta 4
Latest firmeware 4.4.28 and I suspect it's a Sierra issue but I see the drive and shares and am promtped to authenictate which seems to work. Trying to mount or view files results in a time out. Driv...
mdgm-ntgr
Aug 15, 2016NETGEAR Employee Retired
It could well be a bug with Sierra.
Once Sierra is released (I guess probably sometime within the next couple of months) if the issue is still there one would then need to see if there are any workarounds.
ovrdrvn
Should it be much faster to browse in Windows? As I'm using Parallels i'm quite surprised how much faster it seems.
- mdgm-ntgrAug 15, 2016NETGEAR Employee Retired
Well the SMB service is primarily designed for working with Windows.
There have been some improvements in Mac compatibility over time and there is a backend setting change that can be made to speed up directory listing on Mac.- ovrdrvnAug 16, 2016Aspirant
As Apple has reccomned not using and has now disabled AFP, OS X communicates default via SMB. Could you tell me how to make those changes? Sadly, the public beta released yesterday still allows no access. Tried messing with NFS and it was too much to deal with. I hope this works itself out as I have 9TB of media that I'd like to continue to use with this Mac that is in perfect working order (as is the NAS)
- mdgm-ntgrAug 18, 2016NETGEAR Employee Retired
Oops, I was thinking of OS6 not RAIDiator-x86 4.2.x with the backend change. In any case that backend change was for speeding up directory listing not for dealing with a possible bug with Sierra Beta.
As I mentioned above once Sierra is released (I guess probably sometime within the next couple of months) if the issue is still there one would then need to see if there are any workarounds.
